Results 1 to 6 of 6
Thread: Profile division for multilayered wall.
    February 24, 2017
    08:42 PM
    I have a sandwich precast wall in revit modeled as simple wall (120 concrete + 100 insulation + 75 concrete). I split it in to parts, and was able to create a joint with 'divide parts' option applied to each layer. Now I would like to apply fancy division profile to this joint, but revit is not letting me to mirror the joint. I keep getting an error:
    'Profile family cannot be applied to the hosts as the edge match condition is not compatible with the profile on host widths. Division is performed without edge profiles.'
    The family I created has width set to 75mm and the width of the part is 75mm as well. Snip from the family of division profile attached.
    Could you help please?
Name:	division profile.PNG
ID:	38872   Click image for larger version.
ID:	38874   Click image for larger version.
Name:	profile I want to achieve.PNG
    Gold Coast
    2,779
    05:42 AM
    Each layer as a separate wall.
    February 24, 2017
    08:42 PM
    OH, so I can't do it with parts. Quite disappointing!
    Thanks for letting me know. I'll have to remodel it in to separate walls...
    Gold Coast
    2,779
    05:42 AM
    TBH I don't know if it can be done with parts, I just don't use them. Separate walls just work far better for me.
    February 24, 2017
    08:42 PM
    I played with it a little bit more and even if you model it separately, you still need to create an assembly and parts in order to apply a division profile. I now made it work. The sketched profile shape was nto wide enough, which doesn't make sense. Apparently it needs to be bigger than the wall width we want to apply it to.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    380
    09:42 PM
    Very common in Revit. Whenever you cut something with the same dimensions as the object you are cutting with there might be very tiny pieces of geometry left that Revit cannot model.
    Best practice is indeed to try to make you cutting element a big bigger whenever possible.
  1. Wall sweep on an angled wall (modified wall profile)
    Last Post: June 5th, 2018, 08:54 PM
  2. Built-in wall sweep won't cut when editing wall profile
    Last Post: April 27th, 2018, 08:00 PM
  3. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
  4. Wall Sweep does not following the wall profile
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: May 3rd, 2012, 11:14 AM
  5. Wall profile edit - where's the profile outline?
    By DDenton in forum Architecture and General Revit Questions
    Last Post: August 8th, 2011, 08:48 PM
