Results 1 to 2 of 2
Thread: Adaptive component follow 4 paths for bridge box girder
    Lurker
    May 13, 2020
    02:40 AM
    Hola! I'm new to the forum; been using Revit for 7 years and interested in timber engineering!
    I have an issue with a plate girder bridge that I'm modelling using adaptive components. I would ideally like a parametric section of varying dimensions to be applied to the paths but as of yet I can only produce a surface.
    See attached files:
    adaptive_segment_v2 has been repeated along the paths to produce adaptive_segment_form.
    When I try use adaptive_segment_offset_extruded along the curves, it doesn't compute the walls of the extrusion correctly?
    Using Revit 2019!
    Any help much appreciated!
    Ryan
    August 22, 2015
    12
    07:40 PM
    I think you just need to change the offset extruded family so it extrude horizontally.
    Also I would recommend you not using any void if possible. You can just use solid in this case.
    I only moved the adaptive points in your extruded family to get this.
  1. Create form: profile to follow two different paths that blend and merge together
    By cheeko in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 1st, 2019, 09:54 AM
  2. Rectangle Adaptive Component
    By khanghaxuan in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 10th, 2018, 08:39 AM
    Last Post: August 3rd, 2015, 04:15 PM
  4. About Adaptive Component
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 10th, 2014, 03:17 AM
  5. Adaptive Component Help
    By djnelson75 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 3rd, 2011, 07:23 PM
