Results 1 to 6 of 6
Thread: Show elements in elevation as gray
    September 21, 2016
    Boston
    323
    01:56 AM
    I have some wall sections with elements that are shown in elevation, or in the background, if you will. Is there a way to show these elements as gray thin lines, rather than black thin lines?
    May 14, 2012
    518
    10:56 PM
    A couple ideas:
    1) In the VG for that view (preferably via View Templates), you can change the projection settings for the various element types.
    2) Use "Depth Cueing" in VG. You can set at what depth you want elements to start fading, how deep the fading goes and how dark or light the fade goes. (Note: for printing, the view is processed as a raster image, rather than vector, increasing print time as well as file size.)
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    429
    06:56 AM
    2 elevations/sections. The VT of the back one is set to grey. Layer them on top of each other on sheet.
    A few filters in plan to turn the extra sections off.
    11,394
    11:56 PM
    While all these ideas work, it sounds to me like you just need to edit the view template so things in Projection are lighter lineweight, and gray. Just do it in VG or in VG of the VT if you have one applied.
    Expand all cats. Select all. Projection lines > Color override, gray, LW override, select your lightest lineweight.
    Phoenix, AZ
    2,874
    10:56 PM
    Be aware that some subcategories for surface lines also apply to lines in section -- Slab Edges come to mind in particular.
    September 21, 2016
    Boston
    323
    01:56 AM
    Quote Originally Posted by CADiva View Post
    A couple ideas:
    Hey, thank you for this. Where do I find this in the view template. When I click on model display, or any of the categories, the depth cueing option is greyed out
  1. Make elements visible thru other elements (like walls) in an elevation
    By engineer in forum Architecture and General Revit Questions
    Last Post: February 16th, 2018, 02:27 PM
  2. How to show my levels in framing elevation???
    By rishie in forum Architecture and General Revit Questions
    Last Post: June 8th, 2017, 05:03 PM
  3. Copied Elements wont show up
    By dyepaintball45 in forum Architecture and General Revit Questions
    Last Post: February 21st, 2015, 06:35 AM
  4. how to show arch elements in structural sections
    By Username1 in forum Structure - General Questions
    Last Post: January 3rd, 2014, 05:53 PM
  5. Show Duct Bottom Elevation
    By domsib in forum MEP - General
    Last Post: March 20th, 2013, 02:33 PM
