Thread: In trouble with GridLines disappearing
    August 2, 2011
    150
    06:17 PM
    It makes me surprised, some Grid lines are disappeared when i noticed.
    I can't find them in REVEAL HIDDEN ELEMENTS.
    As attached, Grid 1 to 4 are disappeared in certain plans ( 1st Floor Plan and Foundation Plan ).
    The rest of the plans have all the gridlines.
    I firstly thought that I deleted in certain plan but it's not as what i did.
    Please help me solve this.
Name:	Grid Line Disappear_1.JPG
ID:	4640   Click image for larger version.
Name:	Grid Line Disappear_2.JPG
    3,169
    03:17 AM
    Check your elevation/section view, see if the bottom extent of those grids (3D "open circle grip", not 2D filled circle "dot" grip) is still beneath the levels that they don't appear in. If they don't then drag the ends down until they do. The grid's 3D extent (3D end of grid) must cross through the cut plane of the level to show up in views for that level.
    August 2, 2011
    150
    06:17 PM
    Thank you very much.
    It does work.
    I now solve this already by dragging down those grids 1-4 until the cut plane.
    I realized that i happened due to the fact that I made them shorten in my section details to get nicer presentation cuz i didn't know that will happn...
    Thank you again.
    10:17 AM
    If you want to shorten them in your section detail, select them, lookup the text at the end saying 3D (little blue letters), click it, it will turn into 2D. Now you can drag them in just your current view. Global project size won't be affected.
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    02:17 AM
    Suggestion....you may want to "Lock Down" the Shared Levels and Grids workset (Edit the workset with an alternate username, take ownership and don't relinquish at sync) That way nobody can accidentally adjust the 3D extents of a level and grid, it will only allow 2D manipulation only.
    (I open RST with a different username for this purpose)
    Senior Member alexo4141's Avatar
    May 25, 2011
    Qubec, Canada
    548
    06:17 AM
    In our office, we put the levels and grids in a design option named levels and grids.
    That way, we can't even select them except when we enter the design option to edit it.
    I found it was also a good way to avoid unintentional modifications.
    August 2, 2011
    150
    06:17 PM
    All of your suggestions are excellent.
    Thank you all.
  1. gridlines
    Last Post: October 13th, 2011, 06:58 PM
  2. Why do my pipes keep disappearing?
    By Kbreedon in forum MEP - General
    Last Post: August 3rd, 2011, 11:24 PM
  3. David Light: Disappearing 1560 Trapelo Rd, Waltham, MA
    Last Post: July 27th, 2011, 09:11 AM
  4. Visible gridlines in assembly
    By Odemeer in forum Architecture and General Revit Questions
    Last Post: July 19th, 2011, 12:48 PM
  5. Finish Group dialog disappearing?
    By kereed2 in forum Architecture and General Revit Questions
    Last Post: January 3rd, 2011, 05:38 PM
