Thread: I need to remove a base plane of my Pyramid 3 sides (Trihedral)
    Lurker
    May 28, 2020
    07:50 PM
    Question I need to remove a base plane of my Pyramid 3 sides (Trihedral)
    I modelled a triangular pyramid (a trihedral) as a Revit family (the first attached figure) and loaded it my project, I need to remove the base plane to be like the second attached figure.
    Could you advise me how I can do this?
    Thanks,
    ZahraClick image for larger version.
ID:	38935Click image for larger version.
    August 19, 2011
    New Hampshire
    519
    02:50 PM
    If you modeled it as a sweep, change the profile.
    If you modeled it with another method, let us know what you did.
    Last Post: May 30th, 2017, 11:15 AM
    Last Post: November 27th, 2016, 07:45 AM
  3. 3 Sided Triangular Pyramid
    By DanielHurtubise in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 18th, 2016, 09:29 PM
    Last Post: May 8th, 2013, 02:15 AM
    Last Post: August 19th, 2012, 07:49 AM
