Results 1 to 3 of 3
Thread: Residential Foundation Expertise
    New Member Bryon's Avatar
    January 19, 2012
    07:19 PM
    Hey was hoping to see if any builders agree with the way I am running the 2 x 10 floor joist and girders
    on this foundation plan
    Thanks
    BDClick image for larger version.
Name:	The Swinson Residence 5-29-20 - Foundation Plan.png
ID:	38949[ATTACH=Click image for larger version.
Name:	The Swinson Residence 5-29-20 - Floor Plan.png
ID:	38950Click image for larger version.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    297
    06:19 PM
    Hey Bryon. Not sure how your question pertains to Revit. Are you asking how to graphically represent the structural elements on the framing plan?
    If you're asking about framing layout, member sizes, and design efficiency, I would consult with the engineer of record and/or general contractor.
    July 30, 2014
    5
    07:19 PM
    Your framing layout looks fine and the joist spans are definitely doable. I'm sure an argument can be made for turning the direction of the joist 90 degrees but its all a "preference game" at that point. Your layout makes sense to me because you have your line of piers parallel to the long dimension of the building footprint and having equal bays of joist framing.
    I would mention a couple things to keep in mind although they are not set in stone. Its always good practice to have all the joists running in the same direction whenever possible. It is not always feasible or cost efficient in every situation but it should always be considered. Lastly, if you're using hardwood floors in the rooms as a finished material, it is best to install the hardwoods perpendicular to the floor joist framing.This gives you a stronger floor and is sometimes missed by contractors. So if you/your client wants their hardwoods to run in a particular direction, just plan on framing the joist below them perpendicular to it.
  1. Ideate Software is seeking Revit API /.NET C# expertise
    By GlynnisPatterson in forum Career Corner
    Last Post: October 28th, 2019, 07:22 PM
  2. Residential Windows
    Last Post: July 9th, 2017, 03:59 AM
  3. Residential basement
    By eshi1362 in forum MEP - General
    Last Post: April 21st, 2017, 12:18 PM
  4. create Foundation Tag to be placed at foundation corner
    By khalid_omar in forum Structure - Family Creation
    Last Post: March 30th, 2015, 10:16 AM
  5. Factory expertise: File Dialog 'Places'
    By Gordon Price in forum Out There
    Last Post: November 8th, 2014, 03:27 PM
