Thread: Structural Framing automatically offsets with nested family
    Gold Coast
    2,794
    02:53 PM
    Question Structural Framing automatically offsets with nested family
    As I work in Arch., I'm not the greatest when it comes to structural framing families...
    I am nesting cast in plates to either end of a beam family, however when I load into project it causes my existing beams to offset downwards by the amount the end plate overlaps the top face of the beam.
    IE if my beam is 600mm in Height and the end plate is 650mm Height (25mm top and Bottom) the beam will lower in elevation by 25mm.
    The z Offset Value parameter may be 0.00 but the top flange of the beam sits at -25mm.
    The same thing happens if create an extrusion in the beam family, or even just drawing some lines!
    Is this a thing for OOTB structural framing families? Is there a work around?
    I'd rather not place the cast in plates individually as this is a steel framed 15 level tower with concrete lift cores and there are hundreds of these cast ins. Also if a steel member moves I'll have to manually coordinate it. Also, adjusting the z Offset of every single beam would be a nightmare.
    11,091
    11:53 PM
    Yepppp. Structural Framing Family issue. We were JUST discussing this on my Slack Channel tonight, joking about the time (2013) i built Fireproofing in to the Structural Framing families, and this exact thing became a nightmare. LOL.
    Gold Coast
    2,794
    02:53 PM
    I did the same thing the other day (0.5mm fire proofing) but didnt notice it, probably because it's such a small dim.
    Luckily i canned that and used paint parameters instead.
    This z offset thing really blows, structural families are already a PITA as it is. It certainly can't be a "feature".(?)
    December 11, 2010
    Astana
    233
    10:53 AM
    The beam will not move if z/y Justification is set to Origin.
    So, a possible workaround is:
    • Select the beams
    • Change z/y Justification to Origin (the beams will shift)
    • Move them back using Offset Value or change a work plane
    • Replace the beam family.
    Gold Coast
    2,794
    02:53 PM
    Thanks Nurlan, i'll give it a try.
  1. Nested Structural framing doesn't allow control of length
    By Christoph Knerr in forum Structure - Family Creation
    Last Post: September 2nd, 2019, 03:42 AM
  2. Structural Framing Family not behaving
    By MalBim in forum Structure - Family Creation
    Last Post: August 16th, 2017, 07:32 AM
  3. Nested Connection in Structural Framing Family RVT 2016
    By DDennehy in forum Structure - Family Creation
    Last Post: January 5th, 2017, 02:45 PM
  4. Structural Framing Based Family
    By navidhedayati in forum Structure - Family Creation
    Last Post: August 17th, 2016, 04:32 PM
  5. Cutting voids when nested family in framing family issue
    By jh75 in forum Structure - General Questions
    Last Post: October 23rd, 2013, 05:56 AM
