Results 1 to 10 of 12
Thread: Crazy Spot Coordinates
    September 11, 2013
    85
    11:49 AM
    Hi All,
    I've run into a strange issue with coordinates that I've not encountered before.
    I'm working on a small project and the coordinates just seem to have gone crazy - like the scaling is off or something. I've tried setting by Acquire on a DWG and also Specify, but the same issue persists. I can get the right coordinate reading at one point, but at any other point it just comes back with totally unexpected numbers (as in moving miles when I've only selected a point 100m away).
Name:	CRAZY COORDINATES.JPG
    I'm using a standard project template, and the standard 'Horizontal' spot coordinate family.
    No idea what's going on as all other dimensions read as expected.
    Any guidance on what I'm doing wrong would be great!
    Many thanks
    September 11, 2013
    85
    11:49 AM
    I thought it could be rotation, but that seems fine - so to explain further, if I dimension from the bottom right to top left corner of the site DWG I get this dimension:
Name:	CC DIMENSION.JPG
    This is the top left corner of that DWG with a spot coordinate on it (reading totally wrong):
Name:	CC Top Left.JPG
    If I place a spot coordinate in what the project perceives as that top left corner's position, the dimension between those points is many factors smaller than it should be:
Name:	CC Bottom Right.JPG
    Whats going on?!
    11,091
    05:49 AM
    This may be stating the obvious, but are you sure you brought the CAD file in at the correct scale?
    3,310
    05:49 AM
    Looks lie you're a long, long way away from the "Origin"
    In Visibility, expand Site and the turn on the Project Base Point and the Survey Point.
    You'll need to have your Revit elements closer to those.
    September 11, 2013
    85
    11:49 AM
    Hi Dave,
    Sadly not - BP and SP are near to the action:
Name:	CC POINTS.JPG
    September 11, 2013
    85
    11:49 AM
    Everything is dimensionally correct - the coordinate system just seems to working to a totally different scale?
    3,178
    03:49 AM
    Have you checked or altered the units assigned to the spot dimension type?
  8.    #8
    October 25, 2012
    51
    03:49 AM
    yes, weird indeed. what happens when you start with a new project, from the OTB standard template? curious to know if you get the same behavior.
    i've seen something similar in the past, when acquiring coordinates from an Acad civil file. i remember the issue was a cause of the acad file wasn't 'correctly setup', then hacked together as a fix, which made it worse for us trying to use it in Revit. it took a whole new 'correct' civil acad file to remedy the problems...
  9.    #9
    3,178
    03:49 AM
    Can you share the file(s)? Check for Geolocation being used in the DWG. Also does it use Survey Units? There is no such thing in Revit yet so that can account for slight discrepancies regardless.
  10.    #10
    September 11, 2013
    85
    11:49 AM
    Hi All,
    I've stripped the project out and attached for anyone to have a look at.
    I'm convinced I've done something incredibly dumb to produce this behaviour - so please prove me right!
  1. copying spot coordinates
    By sandking in forum Architecture and General Revit Questions
    Last Post: February 15th, 2017, 01:27 PM
  2. RTC: Heres to the crazy ones
    By RTC in forum Blog Feeds
    Last Post: October 30th, 2016, 09:45 PM
  3. Site Setup - Acquire Coordinates vs. Specify Coordinates at a Point
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 7th, 2016, 11:03 PM
  4. Spot coordinates
    Last Post: July 17th, 2012, 01:06 PM
  5. Spot Coordinates on edge of footing
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: February 10th, 2012, 07:48 AM
