Thread: Print revit file to PDF
    March 8, 2020
    14
    12:23 PM
    Arrow Print revit file to PDF
    I tried to print my 36x24 sheets (REVIT 2018) to full size PDF using MS Print to PDF printer option in print drop-down menu, however, max size in drop down menu for print size is 17x11 (Tabloid). Are there other ways to print to full size PDF?
    Can anyone help?
    June 21, 2012
    Tours, France
    1,122
    02:23 PM
    Can you post an image of your PDF printer set up?
    March 8, 2020
    14
    12:23 PM
    Screen shot attached
Name:	Screen Shot 2020-06-12 at 11.21.10 AM.png
    June 21, 2012
    Tours, France
    1,122
    02:23 PM
    Well definitely not a lot of options there to do something!! , I'll rather suggest to you to download a Free PDF converter like PDF creator, regards and sorry for not to have an answer for this!!
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    906
    10:23 PM
    Do tests on ones you choose. Lineweights regions text and just about anything else can all suffer from poor pdf conversion.
    June 21, 2012
    Tours, France
    1,122
    02:23 PM
    Quote Originally Posted by biff View Post
    I haven't had none of those problems before and I've been using that PDF converter for at least 3 years!!
    3,310
    07:23 AM
    We've used both PDF Creator (for multiples) and CutePDF (for singles) for many years & have had great quality with both.
  1. Revit Print file not WYSIWIG
    By daniebotha in forum Architecture and General Revit Questions
    Last Post: June 26th, 2019, 11:58 AM
  2. Print SetUp won't show "Print to PDF"
    By NicolasMelo in forum Architecture and General Revit Questions
    Last Post: April 26th, 2015, 07:34 AM
  3. Print Visible Portion = Offsetting on the print out
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: January 9th, 2015, 05:54 AM
  4. .png file does not print
    Last Post: September 2nd, 2014, 11:47 PM
  5. Print to PDF with Linked File Crashes-Adobe
    By TRWhitehead in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2014, 02:52 PM
