Thread: Wall and Floor not joining how I need them to
    June 17, 2020
    01:01 PM
    So as you can see in my attached wall section, I have a floor with 4 in. of concrete, and 4 in. of compacted gravel, against a concrete retaining wall.
    Is there a way to make the wall cut through the gravel and connect to the concrete portion of the floor? I have the gravel set to "substrate" and sitting below the core boundary of the floor.
    I have been using filled regions in all of my sections to fix this issue but it seems like there should be a better way
Name:	Wall Section2.png
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    251
    07:01 PM
    2 Not allowed! Not allowed!
    It has to do with the priority of the wall layers.
    https://knowledge.autodesk.com/suppo...4BB25-htm.html
    June 17, 2020
    01:01 PM
    Wow, I never knew this. Thank you. It turns out that my floor was joined with the wall correctly however I had a pad in this location as well, which to my knowledge pads cannot be joined with a wall. Is there a way to have pads joined to foundation walls so that I don't have to use a pad AND a floor?
    2,821
    12:01 PM
    no -- fwiw, i had the pad in sections
  1. Joining roof/floor & structural framing
    Last Post: March 1st, 2015, 10:55 AM
  2. Stair not joining first floor slab properly
    By azsaqib in forum Structure - General Questions
    Last Post: December 14th, 2013, 11:16 AM
  3. How to cut wall into floor without joining
    Last Post: November 18th, 2011, 07:14 PM
  4. joining beam-floor
    By tdeferme in forum Structure - General Questions
    Last Post: July 19th, 2011, 12:53 PM
  5. Floor Not Joining Wall Correctly
    Last Post: July 15th, 2011, 08:15 AM
