Thread: Revit Plate/Hole tools are not good
    April 14, 2014
    77
    08:59 AM
    - Revit complains about not being in the right view to the work plane even when you are. Need to switch to a plan view then back to a section view while in the command. Seems like a bug.
    - Plates can not be cut
    - Hole pattern outline only allows rectangle and circle
    - Hole pattern outline can not be edited once drawn
    - Plates cannot be made into assemblies or groups (the ultimate dealbreaker).
    Much more functionality and ease of use with a face based family.
    Has any of this changed in Revit 2021? I am using Revit 2020. I'd like to offer feedback to the devs.
    December 11, 2010
    Astana
    233
    06:59 PM
    1. Improved in Revit 2021
    2. ?
    3. No change, not a big deal.
    4. You can edit in R2021
    5. No change. Instead of groups, you can use Structural Connection.
    I can’t agree, plates and bolts are more convenient, even with their own shortcomings.
    April 14, 2014
    77
    08:59 AM
    2. ?
    I cant agree, plates and bolts are more convenient, even with their own shortcomings.
    I'm glad to see they fixed some of these issues in Revit 2021. Not being able to use assemblies and groups is still a dealbreaker for me. It allows for simple detailing of pieces and assemblies, I love the create views feature of assemblies. Structural Connection doesn't allow this last I tried (and is not plate, which you can plop on any face.)
    December 11, 2010
    Astana
    233
    06:59 PM
    I think it's worth trying to create SC views with Dynamo.
    I don’t see how you can use assemblies with structural connections, because you have to include the beams in the assembly so that they get into view. But what if the same beam needs to be shown on another SC?
    April 14, 2014
    77
    08:59 AM
    I wouldn't detail a connection as an assembly with more than one beam (or column). It'd be assigned to one beam, if it comes shop installed on a beam. If it doesn't, it'd be it's own assembly. If I need to detail multiple framing members in one detail I would just use sections and callouts.
    Is there a tutorial on doing SC views with Dynamo? I haven't done this, sounds interesting.
  1. Isolate plate from a steel connection in Revit 2019
    By RuiBarreiros in forum Structure - General Questions
    Last Post: March 28th, 2019, 11:57 AM
  2. Replies: 2
    Last Post: August 24th, 2018, 06:09 PM
  3. Hole in ribdeck E60 floor.
    By akaplan in forum Structure - General Questions
    Last Post: January 7th, 2016, 02:20 PM
  4. Hole on the slab, how to fill it? Help!
    By Ext5 in forum Architecture and General Revit Questions
    Last Post: May 14th, 2015, 09:10 PM
  5. Revit Express Tools - Revit Family Tools, and lots more.
    By RevitExpressTools in forum Commercial & Free Add-Ins/Extensions
    Last Post: September 28th, 2011, 04:33 PM
