Thread: Revit 2021
    Junior Member therrien's Avatar
    December 20, 2010
    Tecumseh, Ontario
    37
    03:23 AM
    Revit 2021
    I haven't seen much in the way of issue for Revit 2021. Does this mean it was basically an issue free release?
    Or is everyone working from home using 2020 because of CV19? lol
    11,091
    02:23 AM
    Quote Originally Posted by therrien View Post
    Please define what types of *issues* are you asking about?
    Ive rolled it out internally, and at a couple of other clients offices. The 2021 release had less drama during installations (for me and our clients) than some other years have had, and the only issue ive seen so far, had to do with the CTC Revit Express Tools initial release of 2021 versions (21.0.0) sacking BIM 360 functionality in Revit 2021 only (2020 and 2019 were still fine). But they fixed it in the 21.0.1 update.
    December 20, 2010
    Tecumseh, Ontario
    37
    03:23 AM
    By issues I mean "anything". After a new release there's usually a bunch of threads discussing bugs in the software. Because of that, I typically wait for the next update on that release months later before I dive in.
    11,091
    02:23 AM
    Hmmm, i dont know that there are usually bugs being discussed, every year. Maybe i always miss those discussions?
    We've already rolled it out, and our new work is all starting in 2021. We just started one new model in 2020, but thats specifically because that client wanted us to. I dont see anything at the moment that would give me an incentive to wait, other than a few lingering apps that arent released yet.
    3,310
    02:23 AM
    It's not usually threads about "bugs"
    It's more often threads about "Why is this new feature THAT way?"
    or
    "Why didn't they add THIS feature instead!!!!"
    March 5, 2011
    Southern California
    709
    12:23 AM
    8 Not allowed! Not allowed!
    I can tell you that in the past (several years ago) the "R" releases (such as 2015 R1, 2015 R2, etc) were bug fixes. The Revit team only did "new" features/functionality for the major releases, once a year, in the March/April time frame. The other releases throughout the year were just bug fixes.
    That all changed a while back (i dont recall the exact release or time frame). The Revit Dev team adopted an "agile" software development approach, which changed the way that Revit is developed. The team now releases one major release a year, like Revit 2021, in the March/April time frame, which also includes a "file format change", and subsequently also includes any tools that also rely on that file format change. Then there are also the 'quarterly" point releases. (almost quarterly, but not always), such as Revit 2021.1, 2021.2, and (maybe) 2021.3. Each one of these point releases also includes new features/functionality that do NOT rely on, or affect, the file format.
    What I'm really trying to explain is the fallacy that the first "point" release of Revit is a bug fix release. Revit is de-bugged through the entire development cycle! Constantly! To the developers, there is really no difference between Revit 2020.2 and Revit 2021, except that the RVT file format has been updated. As you all know, Revit's TRUE release is based on builds. For instance, I'm currently on 20200220_1100. There is a NEW build of Revit, nearly every hour of every singe day! That's why the build number includes the hour! if we break down the build number for those that may not know: 2020- 02 - 20_1100 was created in 2020, in February (02), on the 20th day (20), at 1100 hours (11am on a 24 hour clock)
    Every one of those builds goes through extensive testing and bug bashing on a "Regression Farm"...a server room full of computers running Revit, and testing each new bit of code the developers have introduced, against every bug that's ever been identified. When it comes to release time, a Build is picked from the list of all the hourly builds that meets a defined criteria for stability and bugs/issues to become an official "Release to Market" build.
    Now, an official Release isn't always perfect...sometimes things slip through that just simply were not identified and caught. It's just the nature of software....it's nearly impossible to test every possible scenario. In that case, we release a hotfix as quickly as possible to fix those issues, which are a "point-point" release...like Revit 2021.0.1
    Hopefully this helps clear things up a bit. The team works extremely hard to assure that every release of Revit is as bug-free as possible. There is no reason to wait until the .1 release to install Revit! There is no difference between 2021.0, 2021.1, 2021.2, or 2022.0 (or any release) in the methods that the development team uses to de-bug Revit!
    1,628
    09:23 AM
    Thanx Scott some interesting info there and a nice look into Revit development.
  8.    #8
    3,178
    12:23 AM
    4 Not allowed! Not allowed!
    Many people/firms have developed a habit of waiting for the first update because they felt it allowed them to avoid any mission critical issues that might crop up. In other words waiting meant other firms would do the testing and they'd benefit from their observations. Some firms take six to twelve months to start actively using the current release.
    With 2020 there was a brief period where they pulled the recent update down until they could resolve an issue that users reported. In that case waiting for the first release/update to deploy wouldn't have helped... In twenty years of using Revit I can only vaguely recall one or two times that firing up the new release right away was met with problems. They've had a pretty solid track record.
  1. Enscape now supports Revit 2021
    By willsud in forum Rendering and Gallery
    Last Post: May 28th, 2020, 02:23 PM
  2. Revit 2021 download issue
    Last Post: May 12th, 2020, 03:27 AM
  3. Revit 2021 shadow problem
    By arsherold in forum Architecture and General Revit Questions
    Last Post: May 9th, 2020, 12:59 AM
  4. Building Coder: What's New in the Revit 2021 API
    Last Post: April 16th, 2020, 10:45 AM
  5. [Revit 2021] What is the wrong with the material Browser?
    By Nsync in forum Architecture and General Revit Questions
    Last Post: April 14th, 2020, 05:44 PM
