Results 1 to 3 of 3
Thread: Revit LT 2020 - Location marker shows up beyond crop region and dictates zoom extents
    June 19, 2020
    12:27 PM
    Using Revit LT 2020 - the location marker seems to be dictating my extents further than the crop region in both interior elevation view and sections view - see attached. Does anyone know a way to either temporarily hide the location marker or disable it completely?
ID:	39034   Click image for larger version.
    3,310
    02:27 PM
    Assuming LT is basically the same as full Revit, that should be one of the Visibility/Graphics settings under Site.
    I believe the you're showing is the Internal Origin (don't have Revit open, so that may not be the exact name)
    That's a new thing in 2020
    June 19, 2020
    12:27 PM
    That was exactly it - thank you!
  1. Edited Crop Region Does Not Crop Filled Region When Printed to PDF
    By KEastman in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2020, 10:18 PM
  2. 2D extents resetting after crop region
    Last Post: January 28th, 2020, 10:29 PM
  3. Zoom Extents + but nothing there??
    By natasha00123 in forum Architecture and General Revit Questions
    Last Post: February 25th, 2014, 04:13 PM
  4. Revit 2014 Zoom Extents
    By Mike Adams in forum Architecture and General Revit Questions
    Last Post: August 28th, 2013, 06:38 PM
  5. Zoom Extents (to fit) - All Windows
    By cellophane in forum Tutorials, Tips & Tricks
    Last Post: February 8th, 2012, 07:58 PM
