Results 1 to 10 of 10
Thread: Family hitboxes
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    329
    04:18 AM
    Family hitboxes
    I have been doing some testing with detail component families that contain family types with varying content size. I've been keeping them simple and using visibility parameters to control everything. No linework or nested detail component are controlled by dimensions. Because of this I'm running to the annoying problem of my hitbox being way to large for most family types. Visibility setting do not control the select-ability of the element.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    400
    08:18 PM
    Cody
    More information needed - What is the question you are asking us?
    What is a Hitbox? Never heard of that term in Revit before?
    2,821
    01:18 AM
    In this case hes talking about a cross selection (right to left) that selects the element when you dont want it to. Visibility doesnt mean non-selectable.
    OP Youll have to rethink your approach. Unless these are just lines and you set them to be Not a Reference youre going to get this just using visibility parameters.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,570
    02:18 AM
    The only way around the giant hitbox is to add a dimensional control to the lines with your visibility control. I've onlky used it once, to deal with showing a rough fire extinguisher coverage distance in the family. If the coverage distance was on, the clearance radius matched the setting in the family (75', typ). If it was hidden, the radius was 2" (or something that prevents the family from breaking, but doesn't extend past the visible bounds). If I was rebuilding I'd probably replace it with a nested family.
    11,088
    03:18 AM
    The nested family still affects the Hitboxes.
    December 31, 2012
    NM, USA
    1,570
    02:18 AM
    I'd probably have it swapping with another one with the visibility, but that probably isn't any simpler than what I'm already doing...
    2,821
    01:18 AM
    I think you have to do more than nest the family and use visibility parameters. There would need to be two nested families (one empty) and a Family Type parameter to swap them. Or use Shared Nested and filter them out of the view.
  8.    #8
    11,088
    03:18 AM
    Whats funny about this, is we've already done the hard work to make that happen, in our doors... but then we didnt do it. (We have a second FT parameter with a formula, so when the vis is unchecked that FT shows "-" which is a blank family). We did it for scheduling purposes, not geometry. But, yeah:
    If i make those Reporters drive the actual Family selection, it DOES minimize the hit boxes.
    I might have to make that a reality in the Doors.
  9.    #9
    August 19, 2011
    New Hampshire
    519
    04:18 AM
    When using nested elements, you should control both visibility options. It isn't enough to unsee the linework, you need to disable the nested element.
    In the image, I nested a linework circle into a detail component. If you control the visibility of the circle using "Circle Linework" (assigning a parameter to the linework visibility in nested component) you will be able to select the detail component when dragging a selection box where the circle is. If you turn off the "Visibility" parameter of a nested element in the parent family, it will disable the nested element in the view.
    Second image is a gif of the scenario.
ID:	39064   Click image for larger version.
  10.    #10
    3,309
    03:18 AM
    I'd be careful with that statement.
    Using this technique does NOT "disable the nested element in the view"
    It disables the element IN THE FAMILY.
    Turning off the visibility of the nested element will affect every View that family is seen in in the entire project
  1. Nesting Generic Annotation Family into Face Based Light Fixture Family
    By dmudd in forum Architecture - Family Creation
    Last Post: November 5th, 2019, 10:44 PM
  2. 2d Family vs 3d Family; Multi-Family Residential
    By deepblue02101996 in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:47 PM
    Last Post: March 27th, 2016, 07:18 AM
    Last Post: March 22nd, 2016, 07:15 PM
  5. Live Session - Family Creation Series #3 | Family Phasing and Geometry Modeling
    Last Post: April 25th, 2012, 07:03 PM
