Thread: custom wall types
    March 11, 2017
    32780
    6
    04:53 PM
    custom wall types
    Hello,
    long time between posts, but this time I need help but I think I might know how already.
    I need to produce a custom wall all the wall need to consist of is a metal sheath and a 1 7/8" interior insulation with vapor barrier. I am planning on modifying a existing wall type after I duplicate it of course with the basic structure I need however the problem comes in with the exterior metal sheath how do I make it look correct ... tried a change to the materials but to no avail. thank you all who respond in advance.
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    144
    10:53 PM
    Quote Originally Posted by Rmandl7660 View Post
    Hello,
    What do you mean exactly by ''making it look correct''?
    You want the metal sheets to show a more detailed profile? Or you just want to use a different material with another pattern on it?
    March 11, 2017
    32780
    6
    04:53 PM
    Sorry so late a reply long day, I have been trying different patterns and jpg. for exterior so it will appear more correct to the original building I simply can not get this close enough to be happy with it so I am saying a more detailed vertical pattern when viewed in elevation or 3d views. and Thank you for your reply it is appreciated.
    January 15, 2020
    The Netherlands
    144
    10:53 PM
    If making a pattern of the metal sheeting is proving to difficult, you could:
    A: use 2d elements in the elevation view to make it look correct in those.
    B: make a 3d element (a family) of the metal sheet and use that in your model.
    Personally i would prefer to make a 3D family from it. A family. But you could also use model in place. When using model in place i would recommend to model them all in 1 model in place object. Because copying a model in place will make it another family thus cluttering your family browser.
    3,310
    03:53 PM
    If you're creating your own pattern, I'd recommend downloading pyRevit
    https://github.com/eirannejad/pyRevit/releases
    They've got a tool named Make Pattern.
    Basically, you draw what you want, and then say "Make this into a pattern"
  1. Copy Wall Architects Wall Types ?
    By sachez143 in forum Structure - General Questions
    Last Post: August 29th, 2018, 06:53 AM
  2. Wall Top Condition in Wall Tag Without a Million Wall Types
    By twocon in forum Architecture and General Revit Questions
    Last Post: August 28th, 2018, 03:18 PM
  3. How do you create custom Line Types
    By Tiffanydh8 in forum Architecture and General Revit Questions
    Last Post: October 18th, 2017, 02:35 PM
  4. Replies: 5
    Last Post: April 12th, 2013, 09:37 PM
  5. Wall types will not display solid fill, strange wall type, and more
    By tweg in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 06:56 PM
