Thread: Parameters in linked revit model
    June 23, 2020
    5
    10:29 PM
    Hi all.
    I have a revit model linked to my own model.
    I want to place a filter on a parameter, but i can't find the paremter by the filter props.
    What can be the reason?
ID:	39039Click image for larger version.
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    144
    10:29 PM
    Is it a shared parameter? If so add the parameter to the project as a global parameter for structural framing.
    I have never tried this but that might work
    June 23, 2020
    5
    10:29 PM
    Thanks for reaction Modderhoop.
    I don't know what kind of parameters they are.
    It is from a linked revit file. So how do i know this?
    If i linked a ifc file, revit make a .txt file in the same map for shared parameters.
    But for a linked revit file there is no .txt file.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    398
    10:29 PM
    Go take a look. Open the Framing family and select the parameter in the Family Types dialog > Edit. There you can see if it's a Shared Parameter.
    If it is, add the SP as a project parameter to Framing in your project. If it's not, start a conversation about what you need to do with the other party, see if they can change some stuff or help you filter in some other way.
    June 23, 2020
    5
    10:29 PM
    I opened the construction revit model. I see it is a shared parameter, they have make a project parameter from it.
    But i missed the shared parameter file from the construction model.
    How can i add this parameter to my shared parameter list?
    April 8, 2011
    398
    10:29 PM
    Project Parameters > select the one > Modify > Export.
    June 23, 2020
    5
    10:29 PM
    Locked
  8.    #8
    June 23, 2020
    5
    10:29 PM
    I think i have to ask the shared parameter file from the constructor.
    Afther that i can make a project parameter.
    Last Post: August 23rd, 2018, 03:15 AM
  2. Copy and Paste To a Revit Model from a Rotated Linked Model
    By Niamhy14 in forum Architecture and General Revit Questions
    Last Post: July 16th, 2018, 05:49 PM
  3. Two Part Question: filtering linked elements & linked model appearance
    By chompi0n in forum Architecture and General Revit Questions
    Last Post: May 16th, 2014, 01:34 PM
    Last Post: April 27th, 2013, 12:45 PM
