Thread: Line weight
    May 31, 2018
    Quebec, Canada
    137
    07:35 PM
    Line weight
    Hi guys,
    I do have a problem with my view template, whatever the line type I put under 3, has no impact.. I watched line weights and they are supposed to be fine it is all different.. I watched line type and it is all assigned to different size 1,2,3 ... what could be the problem?
    thanks
    May 14, 2012
    480
    01:35 PM
    I'm not sure I understand the question, so this may be irrelevant, but here's one thought: Line Weight and Line Pattern are independent of each other in View Templates (as well as Object Styles and Visibility Graphics), so changing the weight (i.e. line thickness) will not change the pattern spread (if that's what you're trying to do). If you want to change the Line Pattern, you have to create (or duplicate/edit) a new one in the Manage > Additional Settings > Line Patterns dialog.
    May 31, 2018
    Quebec, Canada
    137
    07:35 PM
    Ohh it seems it was just a bug, now it seems to work. The lineweight was just not changing but now it does! sorry for this post!
    May 14, 2012
    480
    01:35 PM
    Quote Originally Posted by Midaz View Post
    Did you possibly have "Thin Lines" activated? That catches me sometimes.
  1. Detail components line weight / line control
    Last Post: May 8th, 2019, 04:59 PM
  2. Line weight
    By mhoard in forum MEP - General
    Last Post: March 23rd, 2017, 07:23 PM
  3. Line Weight
    By Himali in forum Architecture and General Revit Questions
    Last Post: June 11th, 2015, 01:34 PM
  4. Line weight setup
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: March 18th, 2014, 11:38 AM
  5. Annotations & title blocks line weight matches thin line status
    By jmk in forum Architecture and General Revit Questions
    Last Post: August 5th, 2013, 07:06 PM
