Thread: H Beam opening by face weird cut
    June 23, 2020
    Alicante (Spain)
    08:08 PM
Name:	Medium level.png
ID:	39041 Click image for larger version.
Name:	Fine level.png
    Hello, I have a problem with Revit LT 2020 and a european HEB steel beam family. In a T joint between 2 beams with the same section, I cut the T beam with the shape of the passing one, using Opening by face. But in the 3D view, the cutting shape shows in fine level when the level is set to medium (left pic), an shows in medium level when it's set to fine (right pic). What am I doing wrong?
    December 11, 2010
    Astana
    235
    12:08 AM
    Hello,
    Сheck if the Detail Levels are correctly assigned to the geometry in the beam family.
    June 23, 2020
    Alicante (Spain)
    08:08 PM
    Quote Originally Posted by Nurlan View Post
    Hello,
    Hi, geometry is well assigned, straight corners in medium level and rounded in fine.
    When I cut the end of the beam with the Opening tool, I pick the lines from the fine level section, so with rounded corners. But then, it shows with straight corners in fine and rounded in medium...
    December 11, 2010
    Astana
    235
    12:08 AM
    I could not recreate this issue in Revit.
    Try changing the family so that it has only one geometry for high and medium detail (remove medium extrusion).
    Does the same thing happen with other I-beam families?
    Create a new project without a template and copy your beams there. Does the problem remain?
    December 13, 2010
    Whangarei, New Zealand
    187
    06:08 AM
    Quote Originally Posted by edu5436 View Post
    I think it is because you are using opening by face. Is there a reason why you aren't using "cope"? "
    Sent from my Mi A3 using Tapatalk
    June 23, 2020
    Alicante (Spain)
    08:08 PM
    Quote Originally Posted by Chris Needham View Post
    Hi, I'm using Revit LT and Cope is not avalaible...
  7.    #7
    December 13, 2010
    187
    06:08 AM
    Oh sorry, didn't realise that.
  1. Partial cut opening for a Beam
    By antonmichel in forum Structure - General Questions
    Last Post: August 31st, 2019, 04:49 PM
  2. Concrete beam acts weird
    By Marco79 in forum Structure - Family Creation
    Last Post: May 13th, 2016, 12:18 PM
  3. Concrete beam acts weird
    By Marco79 in forum Structure - Interoperability
    Last Post: April 6th, 2016, 02:35 PM
  4. Weird Pop-up Dialog when opening Revit or SWC
    By MrBIMtastic in forum Architecture and General Revit Questions
    Last Post: April 16th, 2014, 01:30 PM
  5. Cut shaft or Opening through Beam System
    By Ian.Kidston in forum Structure - General Questions
    Last Post: June 3rd, 2012, 01:58 PM
