Thread: Changing Line Wieghts
    Lurker
    June 24, 2020
    06:39 PM
    Hi All,
    Wondering if someone would be able to assit. Im fairly new to Revit.
    I am trying to change the line weights so in plan it looks like the preview.
    Image 1 is what shows in the preview of the wall looks like in the Edit Assemly window. This is how i would like it in model view
    Image 2 is what it appears on the model
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    143
    10:39 AM
    To change the line weights of cut walls in a plan you go to:
    View template > V/G Overrides Model > (bottom right) Override Host Layers > check the box > Edit...
    Here you can now change the line weight of your different wall functions in a plan.
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    238
    08:39 AM
    hi
    check objects style, it would modify it on your whole project (rather than modify it only on one view)
    Phil
  1. Rotating Reference Line Endpoints Changing
    By RyGuy in forum MEP - Family Creation
    Last Post: March 20th, 2019, 08:13 PM
  2. Single Line pipe (Course Detail) - Changing fill options
    By tom recarb in forum MEP - General
    Last Post: February 26th, 2019, 04:23 PM
  3. Replies: 3
    Last Post: March 1st, 2018, 09:23 AM
  4. Line Based Family : Changing linetype?
    By brinxb in forum Architecture and General Revit Questions
    Last Post: March 15th, 2013, 02:18 PM
  5. Changing Contour Line Map from Rhino
    By h.finn in forum Architecture and General Revit Questions
    Last Post: July 6th, 2012, 02:19 PM
