Thread: Keynote description blank in project, but correct in .txt file
    October 14, 2011
    Boston, MA
    245
    04:30 AM
    The description is showing blank in the project but everything is formatted correctly in the .txt file. One thing I've noticed is that there is an extra period showing in the project keynote schedule that is not there in the .txt file (ex. 11.31.B)
    Keynote Schedule in Project
Name:	Revit Keynote Schedule in Project.png
    Keynote .txt file
    tried retyping out these lines but no luck, any ideas?
    11,088
    04:30 AM
    Any chance thats a SPACE in the text file, instead of a TAB?
    October 14, 2011
    Boston, MA
    245
    04:30 AM
    thanks for the reply, I don't think that's the case. Here I'm viewing in Notepad++ which allows me to view SPACE (.) and TAB (->). Is it possibly a corrupt file
    11,088
    04:30 AM
    Quote Originally Posted by billiam View Post
    I think its the inch symbols, actually. I think you need to have two in a row, to use them.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,570
    03:30 AM
    3 Not allowed! Not allowed!
    Have you looked at the object that has the keynote in the project? Blank descriptions show up when the keynote an item has isn't in the keynote file - That would also explain the discrepancy between periods.
    Ex. "POS" element has keynote 11.31.N, which isn't in the keynote file, thus would show as no description.
    11,088
    04:30 AM
    Good eyes! I hadnt even noticed that.
    October 14, 2011
    Boston, MA
    245
    04:30 AM
    you're exactly right, it wasn't in the keynote file. I was able to re-assign the 'new' keynotes to the description I wanted, and the 11.31.N went away. This does beg the question, how did someone create a new keynote number outside of the keynote .txt file
  8.    #8
    December 31, 2012
    NM, USA
    1,570
    03:30 AM
    You can put any keynote number you want in the field by typing (vs clicking the dots to bring up the associated list). It is nearly always the case in manufacturer content families (where it is done intentionally), but also is likely to occur if items are copied from an older project that used an older/different keynote file. I'll often hand-type the keynote because its faster than clicking down to where it is in the list, but sometimes I miss a character and get the blank field.
  1. Keynote - Blank Row
    By Tinyman in forum MEP - General
    Last Post: June 25th, 2020, 06:35 PM
  2. Best workflow to correct a building location in Revit based on a CAD file
    By giicko in forum Architecture and General Revit Questions
    Last Post: January 20th, 2015, 05:17 AM
  3. Keynote File, Office Wide or Project Specific
    Last Post: October 8th, 2014, 08:20 PM
  4. keynotes: loading entirely new keynote txt file into an existing project
    By TraceStudio in forum Architecture and General Revit Questions
    Last Post: February 10th, 2014, 11:32 PM
