Thread: DWG Import Scaling with Horizontal + Vertical Scales
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    400
    07:31 AM
    I have a Drawing from a Civil Surveyor
    Its an AutoCAD DWG
    It shows me a Property Line, in Elevation showing the ups & downs
    Weird thing is, is that it have a Horizontal & Vertical Scale that are different (1:300 Horizontal & 1:150 Vertical)
    This is how Civil do there Drainage Lines so I can see why they have done it
    Is there a way that I can Scale up there Import within Revit to be To Scale & not have the Wonky Scales?
    February 24, 2011
    Auckland
    400
    07:31 AM
    2 Not allowed! Not allowed!
    OK, YouTube to the rescue
    No Revit trick - Need to do this inside of ACAD
    Copy clip the Elements
    Paste them back in as a Block
    Select block & then non-uniform scale them in the Properties to whatever you want
    done
  1. Horizontal dimension with vertical text
    By User_2011 in forum MEP - General
    Last Post: October 14th, 2019, 07:16 PM
  2. Tag leaders not horizontal/vertical
    By Googleye in forum Architecture and General Revit Questions
    Last Post: April 5th, 2019, 07:31 AM
  3. Horizontal & Vertical Offsets
    By jackmitford in forum Architecture - Family Creation
    Last Post: July 5th, 2018, 01:16 PM
  4. scheduling curtainwall vertical and horizontal mullions
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: June 28th, 2017, 02:15 AM
  5. Mullions: Horizontal and vertical 45 join
    By kosmos3d in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2016, 05:48 PM
