Results 1 to 3 of 3
Thread: Revit 2020 Truss Material Change
    October 23, 2015
    6
    10:31 PM
    Hi All, in Revit 2020 the Structural Truss material is UB-Universal Beams:UB305x165x40. I was looking to change this to be an angle iron type. I could then use this in a barn conversion project.
    However, there doesn't seem to be a way of changeing the truss material in any of the settings and i have not been able to create a new family for one I have attached a pic of what i am trying to create and would welcome any help or links to a source or even a family of the type i show.
    Hope you help
    Stay Safe
Name:	Roof Truss.png
    May 14, 2012
    481
    03:31 PM
    You need to load the angle framing type into the project (from the Structural Framing folder). Then you can change the Structural Framing types for the different truss members.
Name:	Truss member setting.jpg
    When I was testing these instructions, I also had to follow the last bit of advice in this web post: https://aectechtalk.wordpress.com/20...bers-in-revit/
    October 23, 2015
    6
    10:31 PM
    Thanks CADiva, obvious once you know. I read the article from your link and it makes every bit of sense. Learn a little every day thanks again. Stay Safe
  1. Project Files upgraded to Revit 2020 linked DWGs change position
    By willsud in forum Architecture and General Revit Questions
    Last Post: September 19th, 2019, 08:32 AM
  2. Revit does not allow me to change material of imported object
    By soonk in forum Architecture - Family Creation
    Last Post: February 15th, 2018, 06:55 AM
  3. Truss change
    By mhm in forum Architecture and General Revit Questions
    Last Post: December 19th, 2015, 10:32 PM
  4. Replies: 0
    Last Post: December 5th, 2013, 11:15 AM
  5. Change dimensional lumber ends on a truss?
    By tzframpton in forum Structure - General Questions
    Last Post: October 29th, 2012, 09:27 PM
