Thread: Thin Lines
    Lurker
    July 6, 2020
    03:26 AM
    Thin Lines
    Hey guys,
    Just got a new laptop with a high resolution screen. Having problems with the Thin Lines setting where it changes everything to one pixel thick when modeling. Basically because the screen resolution is high 1 pixel seems really thin is hard to see and is hurting my eyes. Is there anyway to change that setting?
    Can change the screen resolution i guess but then everything else doesn't look as sharp and like the screen looking sharp. Generally not a problem as I normal draw at my desk plugged into a bigger screen. But occasionally out and about want to use my laptops screen to draw as that is kind of the point of a laptop.
    Any help in working out how to adjust this setting it would be good. Preferrably to 2 pixels maybe 3, would need to see.
    Thanks for your help.
    11,160
    12:26 PM
    Not possible to alter the setting.
    2,830
    10:26 AM
    2 Not allowed! Not allowed!
    also, stop using Thin Lines so much
    Long Beach, CA
    217
    10:26 AM
    I'm with Greg on this. I really do not like modeling with Thin Lines enabled.....only use it when troubleshooting.
    Me? For my working views, i bump view scale to something like 1/2"=1'-0" which preserves lineweights while making everything very clear to see. I notice most staff leave it at 1/8" which i find less conducive to modeling. Fine for documentation. But that's just me. YMMV.
    Jon
    p.s. many other ways to skin the cat. You can use view templates to change object lineweights in view, etc etc. The view scale is the quickest though....
    January 27, 2017
    48
    05:26 PM
    Quote Originally Posted by kingjosiah View Post
    Jon
    I am legitly wondering why is it that you choose to work with thin lines disabled. Personally i find it offers a great deal of precision which otherwise would not be reached without this option being activated.
    May 14, 2012
    487
    11:26 AM
    Quote Originally Posted by snuffy View Post
    We all have our preferences. If that works for you without interfering with how the final documents come out, then great. Like others, I work primarily with Thin Lines off and only turn it on for specific tasks because I like to keep an eye out on the line weights as I work.
    Long Beach, CA
    217
    10:26 AM
    Quite simply because *none* of the precision is sacrificed AND i am very quickly to determine what each line represents because there is a lineweight associated with it. We architects are a visual bunch and lineweights help to inform. I never said i don't use Thin Lines.....but i reserve it for times when needing to discern between very small minute distances. For general modeling, changing View Scale allows me to see everything i need, e.g. layers of GWB.
    As CADiva noted.....everyone has their own preferences. Below are images of a plan with my visual preference, and one with the default 1/8". Clearly, one is easier to read. I invite you to give this workflow a try. You might actually like it.
    Jon
ID:	39089   Click image for larger version.
Name:	Plan 0.125.jpg
  1. Printing Thin Lines to PDF
    By Noam_r in forum Architecture and General Revit Questions
    Last Post: June 28th, 2018, 09:08 PM
  2. Thin Lines, Revit Start up
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: October 1st, 2015, 04:10 PM
  3. Thin Lines vs No Thin Lines in 2014
    By MPwuzhere in forum Architecture and General Revit Questions
    Last Post: July 19th, 2013, 03:19 PM
  4. Thin Lines...
    Last Post: May 25th, 2011, 05:11 PM
  5. Printing grey vs thin lines
    Last Post: March 30th, 2011, 03:38 AM
