Thread: Find way to having vertical mullions parameter in schedule Revit.
    Junior Member ricomarcoux's Avatar
    January 9, 2018
    Drummondville, Qc. Canada
    15
    01:20 PM
    I Work on Revit for a structural wood building. I use a curtain wall and have a schedule for a description of the wall. The problem is i can't add mullions parameter and vertical grid parameter in my schedule
    Have you a way to having the spacing and mullion type of a curtain wall in the scedule?
    Thanks for your help
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,574
    10:20 AM
    mullion type is easy, just schedule the Type parameter of the Curtain Wall Mullion category. To schedule a vertical mullion horizontal spacing would be a bit more involved but can be done. It would involve separating the horizontal mullions from the vertical mullions, schedule the horizontal mullion lengths, and via formula add a vertical mullion face width to achieve the center to center spacing.
    January 9, 2018
    15
    01:20 PM
    But we can't identify the mullion in the schedule wall?
    Because my identification is based on the wall.
    actually what i do is add a text shared parameter and identify the mullion and distance with it.
    Revit.... Have to add parameter for write something i have in the parameter of the curtain wall...
    Dave Jones's Avatar
    4,574
    10:20 AM
    Quote Originally Posted by ricomarcoux View Post
    How to schedule mullion TYPES: View tab and select the Schedules down arrow. Select Schedule/Quantities and in the New Schedule dialog select Curtain Wall Mullions which will make your schedule a Mullion schedule. In the Schedule Properties dialog select TYPE in the available fields list and hit the green right arrow to add this parameter to the scheduled fields (you can add other fields here if you wish). Hit OK and a schedule is created with a list of all of your mullion types in your project. In the Schedule Properties you can now use the Fields, Filter, Sorting/Grouping, Formatting, or Appearance tabs to refine the look and content of your schedule. For instance, if you don't want each and every single mullion type listed in the schedule select the Sorting/Grouping tab and unselect Itemize Every Instance and your schedule will combine all like mullion types in single rows.
    January 9, 2018
    15
    01:20 PM
    Yess I know that. What i nedd is:
    I create a Curtain wall with empty panel for make structural wood wall.
    I need to put in shcedule Wall type MR-1 have 2x6 at 16" for example.
    My schedule his a wall Schedule.
    Add pictures to help
    If you see, i create shared parameter for addig parameter in the wall schedule but this parameter already exist in the mullions setting of the wall
    Thank you Dave for your point. Appreciate that!
ID:	39084   Click image for larger version.
ID:	39085   Click image for larger version.
    11,160
    12:20 PM
    Having done a fair amount of Wall/Partition Framing in Revit... i wouldnt use Curtain Walls for it, at all. They are fast on the front end, but there are a ton of conditions where they absolutely suck to work with, for Framing. I would use individual families, and Dynamo (only if you REALLY want to build in a layer of complexity for placing them quickly).
  1. Vertical Schedule
    By Vester85 in forum Architecture and General Revit Questions
    Last Post: September 24th, 2017, 09:42 PM
  2. scheduling curtainwall vertical and horizontal mullions
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: June 28th, 2017, 02:15 AM
  3. Mullions: Horizontal and vertical 45 join
    By kosmos3d in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2016, 05:48 PM
  4. vertical Mullions bottom end line up at bottom of transom
    By balzo in forum Architecture and General Revit Questions
    Last Post: June 26th, 2015, 01:38 PM
  5. instance parameter for curtain wall mullions randomizer
    By karpov005 in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2014, 06:51 AM
