Results 1 to 10 of 14
Thread: Can Dynamo harvest Scope Box points/rotation?
    Member aperte's Avatar
    94
    03:00 AM
    I've got a complex campus project, with different design wings at a variety of orientations to True North. All in one file, so SCOPE BOXES are used extensively to crop views consistently, and to rotate those viewports to an orthogonal position on sheets.
    Issue is our Consultants are having issues with matching our rotations, and even though we can have them copy/paste the SCOPE BOXES themselves, the rotation appears to be non-defined. We can't dimension the angle, we can't place reference planes to 'snap' to the corners of it.
    I've read through several SCOPE BOX topic posts from the past, and it seems impossible to harvest data from them through the standard Revit interface, or from a variety of tools (Ideate Explorer and BIMLink were my first data extraction attempts).
    Is Dynamo capable of extracting out points of Scope Boxes, and rotation to True North data from them?
    iGracias!
    94
    03:00 AM
    Also, Scope Boxes apparently don't export to DWG, so I can't gather coordinate data from that method, either. Hopefully I'm just missing something, but this is getting frustrating!
    94
    03:00 AM
    I took a look at this: https://forum.dynamobim.com/t/scope-box-location/13200
    Which would create a bounding box for a selected Scope box, however as the discussion notes, rotated scope boxes would risk having their corner points shifted, which is a NO GO for my situation.
    11,150
    05:00 AM
    Assign a floor plan view to each scope box, turn off annotation crop, set crop regions to be visible when printing or exporting, and export the views to DWG?
    I've never tried that so I have no idea if it will work. If so,I'd be curious if it would work to export the parent view (assuming they are dependents) so you only had to export one?
    Guessing on both counts, as I'm on my phone and not at a computer.
    94
    03:00 AM
    Thanks, Aaron - not a bad idea at all.... I'll give that a go and see if that gives us what we need!
    94
    03:00 AM
    Well, not successful. There IS a setting to show/hide scope boxes (General), but even when setting it to show SBs, they didn't export.
    I was able to print them showing to PDF, contemplating how to work with it from there... Vector PDF to Illustrator to DWG? ugh. But if it works, better than nothing...
  7.    #7
    Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    90
    05:00 AM
    So it does appear that you can extract the Geometry from the Scope Box, regardless of if its rotated. Then that can be broken down into its four lines. Or four points extracted from those lines.
    Hope that gives you a start, if that is what you are after?
    Bear in mind that will give you the Internal Coordinates. You would then be responsible for rotating per your true north.
  8.    #8
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    402
    12:00 PM
    Yes, the lines and points seems to be easy. The question then becomes how to coordinate that into other files since Scope Boxes do not have any create methods associated with them. Maybe generate some lines or place some family at the corner points so other people can eyeball the location? Does not seem like a great solution.
    Springs package has some easy Nodes for getting the Solid/Lines/Points.
  9.    #9
    94
    03:00 AM
    Thanks for the screenshot, Kraftwerk - I went to Github to download that tool, looks like only 2017/2018 versions are available. I do think it would give me what I'm looking for, or at least the ability to use that data to construct a DWG layout. Will see what the installer gives me, and if I can use it in R2019.
  10.    #10
    94
    03:00 AM
    Thanks, Bjorn - I'll see if I can use this process, if the LookUp tool isn't working for me - appreciate the reply!
    Last Post: June 18th, 2018, 06:15 PM
  2. Replies: 7
    Last Post: April 24th, 2017, 05:52 AM
  3. Replies: 2
    Last Post: December 20th, 2016, 06:51 AM
  4. Get rotation of doors with Dynamo in Revit
    By engineer in forum Dynamo BIM
    Last Post: September 8th, 2016, 03:22 PM
  5. Rotation of normal plane in adaptive points
    By Rodrigo Romero in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 12th, 2015, 02:34 AM
