Thread: Steel - Contour Cut not showing in Fine Detail view
    July 15, 2020
    5
    09:21 AM
    I'm attempting to apply a contour cut to a member because structural connections do not allow a top flange cope on moment connections.
    I've successfully drawn the contour profile, but it is only visible on "Medium" detail level, but I need to see my other structural connections, so I must use "Fine" detail...Screen shots are below. First image shows I have applied double clip angles, and I have already applied the contour cut. 2nd picture, I've selected the beam with the cut, and you can see the outline of the cut profile. Both views are on "Fine" detail. Third picture, I've switched to "Medium" detail, and you can see the cut clearly, but the angles are gone...
    My understanding of the Contour Cut from Autodesk's help sites is that it only shows up on Fine detail views, but I'm having the opposite results. Anybody else have any issues or recommendations?
    July 15, 2020
    5
    09:21 AM
    Apparently the pictures did not come through. I'll try to post one here.
    July 15, 2020
    5
    09:21 AM
    A solution has been found within the office (thank you @TFuller).
    Apparently, the issue is caused by the inner face of the top/bottom flanges. If a line is snapped to either of those faces, the cut will not show up in fine detail. After playing around with the sketch profile, I determined that there is a minimum threshold of 0.0632" from that face. Once you hit that threshold, the cut becomes visible, but anything under that value renders the contour cut invisible.
    3,358
    09:21 AM
    Quote Originally Posted by schnautza View Post
    Since you're a new user, your first 5 posts are moderated.
    After you make a few more posts, you'll be able to post pictures
    And welcome to RFO!
    July 15, 2020
    5
    09:21 AM
    And welcome to RFO!
    Thanks for clarifying. I was wondering why my original post took so long to go thru, especially since the "Permissions" on the bottom of the "new post" page all say "You may..."
    I guess after this one clears, I need one more post before I can post any accompanying pictures of the problem as well as the solution that was found, just in case anybody else ends up with this issue down the road and stumbles across this thread.
  1. Pipes not showing unless Fine View
    By yasurah in forum MEP - General
    Last Post: July 17th, 2020, 02:36 PM
  2. New contour lines not showing through sub region
    By HenryD in forum Architecture and General Revit Questions
    Last Post: May 1st, 2018, 04:36 PM
  3. Detail to fine
    By Suntalic in forum Architecture and General Revit Questions
    Last Post: August 18th, 2016, 09:41 AM
  4. Project file fine in PC corrupt when opened in Laptop, other files work fine
    By craig11111 in forum Architecture and General Revit Questions
    Last Post: June 10th, 2014, 02:18 PM
  5. Problem with activating fine detail level in plan view
    By popes2 in forum Architecture and General Revit Questions
    Last Post: December 28th, 2013, 05:10 PM
