Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: Revit 2020 Stuck but looks fine
  1.    #31
    3,359
    03:13 PM
    Heard back from Enscape Support.
    They expect a fix next week
    The last message regarding this subject for now:
    This issue shall be resolved in the next upcoming preview, or hotfix, coming out in around the next week.
    Stay tuned and let me know in case you have any further inquiries what so ever.
    Kind regards
  2.    #32
    11,165
    03:13 PM
    Upcoming PREVIEW, or hotfix? They best release an updated installer, or i guess a bunch of us are just skipping 2.8.
  3.    #33
    Member johnp's Avatar
    March 24, 2015
    181
    02:13 PM
    This is going to sound weird. But Back in like Revit 2015 we saw similar issues where you could not click on anything in Revit, but it looked fine.
    The fix was to go to the ? menu> About Autodesk Revit > Manage License > Then Exit that menu. And boom, Revit would come back.
  4.    #34
    3,359
    03:13 PM
    Heard back from Enscape support this morning.
    Still no fix, but they did suggest a potential work-around
    Hi Dave,
    Thanks a lot for your patience.
    I'm afraid not just yet, we're still in the process of resolving this problem. In the meantime, you may want to use the workaround provided in this thread here:
    https://forum.enscape3d.com/index.ph...tral/&pageNo=2
    If you just check out the last reply from "Magnus Jeppsson":
    "One solution for another user in my company was to uninstall Enscape, delete the AppData Roaming folder (e.g. C:\Users\ini\AppData\Roaming\Autodesk\Revit\Addins \2020\ -->Enscape folder), and then installing Enscape again.
    They had it working like normal again with 2.8.0.26218."
    Thanks a lot again for a bit more patience.
    Kind regards,
    Demian Gutberlet
    Enscape Support
    Last Post: February 12th, 2020, 04:45 AM
  2. Revit 2020.2 on old 2020 install
    By Robin Deurloo in forum Hardware and Infrastructure
    Last Post: November 25th, 2019, 01:47 PM
  3. Stuck in Revit Formula
    By cbelzer in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2014, 08:04 PM
  4. Project file fine in PC corrupt when opened in Laptop, other files work fine
    By craig11111 in forum Architecture and General Revit Questions
    Last Post: June 10th, 2014, 02:18 PM
  5. Do U Revit: Fine-tuning of material surface patterns
    Last Post: April 20th, 2012, 05:45 AM
