Results 1 to 10 of 13
Thread: Coordinates Errors
    2,830
    02:14 AM
    Coordinates Errors
    I noticed something in a recent file that got me headed down a "what the hell is going on" path.
    It started with a civil file that had all sorts of issues and I had been assuming the issue originated and was isolated to the use of the DWG but I'm seeing the same thing in a new project based on no templates.
Name:	coordinates error 01.png
    in this file i created some lines for reference about the Revit internal orgin (RIO -- this is in 2018, BTW so we're at the "default location") and copied them over as shown with Units set to decimal feet to the 12th decimal. So far, so good. The spot coordinate relects the corrrect value.
    However, as I start to increase the distance from the survey point (currenlty at the RIO) to larger values, as might/will occur in locating a project relative to the civil file, we start getting what I assume to be rounding errors.
Name:	coordinates error 02.png
    And if i put the Survey Point where it belongs relative to the civil file the errors get more prounounced.
Name:	coordinates error 03.png
    So what gives? Before I tried the example in the first image I thought perhaps Revit was converting the decimal feet to rounded (to the nearest 1/256") imperial units but if that were the case then we should see those same error at 10feet from the SP as well.
    2,830
    02:14 AM
    2020 has the same issue, FWIW.
Name:	coordinates error 2020.png
    11,163
    04:14 AM
    Wait: You moved the Survey point far away, to create that... Or left the SP at the RIO, and moved all your stuff a mile away?
    2,830
    02:14 AM
    moved the survey point using Specify Coordinates at a Point -- the PBP is sitting at the RIO
    11,163
    04:14 AM
    Cool, cool. Was misreading the post, at first.
    So, if you do it in a blank file, but do SCAP *before* you move and dimension the objects, does it still behave that way?
    Ive seen the last digit get slightly whacked like that if there is any rotation of True North as well (which is damn always), so the very last decimal, i dont pay much mind too.
    2,830
    02:14 AM
    yes - same issue --- i know that past even 4 decimals we're talking about things that can't be measured in the field but i'd hope that wouldn't matter
    if i take it to 9 decimal places the issue "goes away"
    3,188
    02:14 AM
    If I use SCaP I always assign the project units to the same as the values I am going to provide. If six decimal places I set it to the same. If I leave the units set to feet and fractional issues then I see some rounding occur. It's worse when the number of decimal places is increased. I find that playing the units game stores the values faithfully even if I switch back and forth after using SCaP. I've never had to do that for Acquire Coordinates, it seems to capture the values and store them consistently without rounding per current units.
    Generally I only worry about six decimal places, everything past that is so small it will never materialize IRL.
  8.    #8
    11,163
    04:14 AM
    Most fo the folks on site that i work with ask for between 3 and 6, as Steve said. I push the accuracy all the way down like that, id im trying to work out a CadKink, somewhere in the model. But yeah, that last decimal is just a gnats ass.
  9.    #9
    2,830
    02:14 AM
    of course it is -- and, like you two, i'd never show anything past 3-4 (or whatever)
    what concerns me is that this looks like a CadKink but it's not and that's going to make convincing others who don't beleive (or who don't want to beleieve) there are issues with DWG in Revit -- if the one thing I can use to show people that Revit doesn't like DWG happens without any DWG in the model well then WTF?
    seems there's more challengs with Revit's math engine than I thought
  10.    #10
    3,188
    02:14 AM
    Are the lines you are using actually that far from the IO now?
  1. Worksharing Errors - 2018.3.1
    By jsnyder in forum Architecture and General Revit Questions
    Last Post: December 19th, 2018, 01:06 PM
  2. Site Setup - Acquire Coordinates vs. Specify Coordinates at a Point
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 7th, 2016, 11:03 PM
  3. Worksharing Model Errors
    By RLBishop in forum Architecture and General Revit Questions
    Last Post: December 4th, 2015, 05:01 AM
  4. Installation Errors
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 02:44 PM
