Thread: Cutting the end of a wall at an angle
    September 21, 2016
    Boston
    289
    03:37 AM
    I have a linked model and a host model. I want to be able to join the wall to the linked model, right now it's not joining. As shown in the image, i want to cut off that extra triangle piece. Is there a way to do this by either joining the wall to the linked model, or editing the end of the wall itself?
Name:	Wall Cut Angle.jpg
    11,160
    02:37 AM
    Quote Originally Posted by katewood1989 View Post
    A Generic Model Family that has a void in it, that you manually place or align where you want it to cut the wall, then do Cut Geometry.
    Or Copy/Monitor that wall in to your model.
    There is no way to interact with the Linked Model.
    May 18, 2011
    Calgary, AB
    443
    01:37 AM
    Tried to make a 2 level void GM and wouldn't let me select the void to cut. A regular GM worked though.
    11,160
    02:37 AM
    Quote Originally Posted by cheinaranta View Post
    Are you sure you had that 2LGM set to Cut with Voids? I use 2L GM's for all of me Penetration Families, and they cut. Unless i missed something...
    Long Beach, CA
    217
    12:37 AM
    Kate (?)....
    Try this family that i posted in another thread.
    https://revitforum.org/showthread.ph...l=1#post229477
    Hope this helps.
    Jon
    May 18, 2011
    Calgary, AB
    443
    01:37 AM
    I can't guarantee that I bet that was the problem.
    Any good reason to not have that checked off by default in the family template?
  1. Baluster not cutting at 'Top Cut Angle' reference plane
    By theoryshaw in forum Architecture - Family Creation
    Last Post: September 17th, 2018, 07:10 PM
  2. door not cutting wall
    By jmuratore in forum Architecture and General Revit Questions
    Last Post: April 3rd, 2015, 08:04 PM
  3. Wall extrusions cutting everything
    Last Post: June 24th, 2014, 12:01 AM
  4. cutting wall sweeps with viods
    Last Post: January 11th, 2014, 05:12 AM
  5. Wall Sweep Cutting
    Last Post: September 20th, 2012, 04:23 PM
