Thread: Visibility of services, cable trays
    February 23, 2017
    7
    06:24 PM
    Hi there. I'm having fun with the view range in my RCP. There is a ceiling grid & tile at 3000 afl throughout most of the floor. There is an area with no ceiling, i.e. exposed slab above, therefore the services (cable trays, etc) should be visible. However when I change my top range to include the cable trays, they also show through the ceiling tiles (circled in yellow below). I just want to be able to see them in the exposed slab area, as one would when looking up.
    Thanks for any assistance.
Name:	View Range settings.JPG
ID:	39159   Click image for larger version.
Name:	Cable trays.JPG
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,574
    11:24 PM
    Quote Originally Posted by SJVandal View Post
    Use a Plan region
    September 19, 2017
    Seattle, WA
    96
    11:24 PM
    Plan Region OR change your view discipline from one of the service types (i.e. Electrical, Mechanical, Plumbing) to Coordination. The "service" types shifts a large number of elements into displaying as an underlay which is another reason why you'd see cable tray above ceilings.
    February 23, 2017
    7
    06:24 PM
    Thanks Robert. It is already set to Coordination. I guess a plan region is the answer - it just seems messy.
    Wellington, New Zealand
    740
    06:24 PM
    Change the view discipline to Architectural and that problem goes away
  1. Get cable trays that are vertical
    By engineer in forum Dynamo BIM
    Last Post: September 20th, 2018, 08:46 AM
  2. Cable Trays = System Family?
    By ricksaus in forum Architecture and General Revit Questions
    Last Post: October 24th, 2017, 03:47 PM
  3. Make different Tags as default at different Cable Trays
    By engineer in forum MEP - General
    Last Post: October 20th, 2015, 03:41 PM
  4. Electrical Cable trays
    By RAJESH87 in forum MEP - General
    Last Post: November 4th, 2014, 08:31 AM
  5. Cable Trays & Colours
    Last Post: July 17th, 2014, 04:14 PM
