Results 1 to 10 of 19
Thread: 2021.1 update requires original install files
    3,354
    04:56 PM
    Apparently, the 2021.1 update requires you to have the files in place that you used to originally install 2021
Name:	2021 update.PNG
    Rotterdam, South Holland
    3,076
    11:56 PM
    Dave, my understanding is that ADSK considers this kind of behavior a bug. Worth reporting. I hope to do a bunch of testing this week and give them a whole list of whatever is... jacked.
    That said, I may have a workaround, which I will test this weekend too.
    And that said, some folks are seeing some issues post 2021.1, so it might be worth giving this update a week or two to see what shakes out.
    Member Geert's Avatar
    February 8, 2011
    187
    11:56 PM
    ran into the same problem. and had to download themagain because I removed themsome time ago
    3,354
    04:56 PM
    Thanks, Gordon. I'll file a SR
    3,354
    04:56 PM
    Wouldn't you know it.
    As I was about to hit the "Submit" on my Support Request, all of a sudden the install picked up again and completed successfully !
    I assume the delay was caused by the fact that I'm on a VPN.
    The update was looking for my original 2021.0 installation media on my C: drive, which I had moved to the network after 2021 was installed
    After the prompt in my image, I browsed to the new network location and had almost given up hope.
    It must have been downloading a boatload of stuff across the VPN and took over an hour and a half to finish.
    If I hadn't gotten distracted with Zoom meetings, I would have given up much sooner.
    TLDR; it did eventually complete the update
    11,152
    04:56 PM
    They keep saying its a bug, but it keeps happening year after year. 2020 point releases went looking for source deployments as well.
    Ive basically assumed every single version since 2015, needs OG source material.
    Wellington, New Zealand
    740
    09:56 AM
    Dave, my understanding is that ADSK considers this kind of behavior a bug. Worth reporting........
    Unfortunately Autodesk dont see it as a bug: its even in the release notes:
  8.    #8
    3,076
    11:56 PM
    Yeah, they are a bit clueless. But my understanding from non marketing sources is that it is a bug, so I'll bring it up with them. And there MAY be a workaround, which I will test this weekend.
  9.    #9
    February 8, 2011
    187
    11:56 PM
    Any news on the workaround?
    A downloaded the original revit 2021 files again but the update installer complains it does not recognize the RVT.msi file
  10.    #10
    11,152
    04:56 PM
    Quote Originally Posted by Geert View Post
    Click browse, in that dialogue that pops up. Then navigate to the RVT.msi in the installer package you just downloaded.
    It will be in: \\WhereverYouDownloadedTheInstallerToo\InstallerPa ckageName\Img\x64\RVT
  1. replace/update families in revit files at opening?
    By mifu in forum Tutorials, Tips & Tricks
    Last Post: February 13th, 2017, 06:44 AM
  2. How to install or update DynamoBIM
    By Simply Complex in forum Blog Feeds
    Last Post: March 28th, 2015, 04:45 PM
  3. OneBox Web Update install on Discipline vertical?
    By Gordon Price in forum Out There
    Last Post: September 25th, 2014, 01:46 PM
    Last Post: October 26th, 2012, 01:16 AM
    Last Post: June 1st, 2012, 03:22 AM
