Thread: Combining areas for multi level unit
    June 6, 2019
    Washington DC
    14
    04:28 PM
ID:	39170Hello, I am working with area schedules and am having a problem with multi level units displaying separately in the schedule. how can i make this schedule to only display the unit once with the correct total sqft.
    11,165
    03:28 PM
    Quote Originally Posted by ndog View Post
    1. Tell the schedule to sort by Name, and NOT itemize every instance.
    2. Tell the Area column to Calculate Totals
    June 6, 2019
    Washington DC
    14
    04:28 PM
    now the area schedule by type is showing the duplicates. Any idea? there should only be 1 3 bed 3.5 bath.Click image for larger version.
    11,165
    03:28 PM
    I mean, go check those two areas, and look at their properties. Because according to Revit, there are two of them.
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    477
    06:28 AM
    Try this:
    Create a Project Parameter named ApartmentCount. Make it Integer, under Identity Data, Instance, and apply it to Category: Areas.
    In each of your Area objects set the value of ApartmentCount to be 1, except for the second level of your double story apartments. For those, make it 0.
    To your Area Schedule, add the ApartmentCount parameter; and under Formatting, set it to Calculate Totals.
    Yes, it is a bit of work, but I think it will get you what you want.
  1. Multi-Unit Patio Home Renovation Project Setup
    Last Post: July 11th, 2019, 04:20 PM
  2. Metric Level Head - Unwanted space between elevation and unit
    By BLothian in forum Architecture - Family Creation
    Last Post: January 13th, 2018, 12:53 PM
    Last Post: May 28th, 2013, 02:15 PM
  4. Using groups for multi-unit buildings with different floor-to-floor heights
    Last Post: February 12th, 2013, 11:23 AM
  5. how to document multi unit development
    Last Post: September 23rd, 2012, 03:00 PM
