Thread: Surface pattern material line weight inconsistantcy
    September 21, 2016
    Boston
    286
    07:34 PM
    I two linked model in my main model, I am using the same material with the same surface pattern in all models, but the line-weight of the pattern displays differently in the linked models (see attached). I don't see any setting within the material editor that lets me control the surface pattern lightweight. Why would the linked model look different than the main model and how do I adjust this?
    When I open the linked model itself, it looks correct. It's only when I load it into the main model, that it doesn't look correct compared to the main model DESPITE being the same wall material that was copied and pasted into all the models.
Name:	Revit materal surface pattern issue.PNG
    May 14, 2012
    487
    05:34 PM
    Surface patterns are controlled by Lineweight 1 ... are these the same in all models? (Manage Tab > Additional Settings > Lineweights ... compare all scales)
    3,351
    06:34 PM
    Do you have your Link set to Halftone?
    September 21, 2016
    Boston
    286
    07:34 PM
    This is exactly what it is! thank you. It looks like the scales in the linked model are 1 : 10, 1 : 20 and so on.. but in the main model it's 1" = 1'-0, 1/2" = 1'-0" and so on. How do I change the linked model scales to match the main model?
    May 14, 2012
    487
    05:34 PM
    Quote Originally Posted by katewood1989 View Post
    I don't know if it matters, but it sounds like the linked files have metric units, rather than imperial units. Those can be changed at Manage Tab > Project Units. What happens to the scales in the Lineweight settings? Do they stay as 1:10, etc. or change similar to 1"=1'-0"?
    It looks like you have the option to "Add" or "Delete" scales in the Line Weights settings, but not to edit them.
  1. Cut Pattern Hatch Line-weight. please help!
    By billiam in forum Architecture and General Revit Questions
    Last Post: April 26th, 2017, 10:03 PM
  2. Material Surface Pattern
    By dzatto in forum Architecture and General Revit Questions
    Last Post: June 15th, 2015, 04:16 PM
  3. fill pattern line weight
    By tomas92 in forum Architecture and General Revit Questions
    Last Post: December 12th, 2013, 01:46 PM
  4. Assigning line weight to material
    By hommes77 in forum Architecture and General Revit Questions
    Last Post: June 8th, 2013, 09:46 AM
  5. Roof surface pattern, where i can change line weight?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: June 15th, 2011, 11:51 PM
