Results 1 to 9 of 9
Thread: In-Place Generic Model Display Issue
    September 21, 2016
    Boston
    286
    07:37 PM
    I made an in place generic model family of an overhang / canopy. Its composed of a translucent glazing set on top of a steel structure below. It's not displaying with the material attributes. It just looks like white boxes (See attached image 1) when I select it, however, it shows the way I Want to see it, with the correct surface patterns and material transparencies. (see image 2). I want it to look like it does when selected. I tried adjusting the detail level to no avail. How do I fix this?
Name:	Generic Model - 2.PNG
ID:	39183   Click image for larger version.
Name:	Generic Model - 1.PNG
    Member aperte's Avatar
    94
    04:37 PM
    What phase is the element created as? Is there a Phase Filter that is overriding materials for that phase applied to the view?
    September 21, 2016
    Boston
    286
    07:37 PM
    unfortunately, it's not a phase issue. Everything is on the same phase.
    3,188
    04:37 PM
    If I understand what I'm seeing, I think it will need to be within the Primary Range of View Range and not in View Depth.
    September 21, 2016
    Boston
    286
    07:37 PM
    Can you please clarify what you mean by this?
    3,188
    04:37 PM
    You wrote:
    Quote Originally Posted by katewood1989
    ...an overhang / canopy. It's composed of a translucent glazing set on top of a steel structure below...
    That leads me to believe you are looking down at the overhang in the views you shared. If so, the view range of that view needs to be adjusted so that the primary range of the view range is deep enough to include the overhang elements so that projection/cut appearance controls can interact with it. If the overhang is only visible within the View Depth of View Range then it has less control over the appearance of the element, it is drawn with the <Beyond> linestyle and patterns etc. don't get shown.
    September 21, 2016
    Boston
    286
    07:37 PM
    Thank you for your response. I am still having issues. This is what it looks like in plan and in section as well as the view depth (see attached images) Thank you for your patience. This is driving me crazy. Hopefully there is an easy solution.
Name:	Visibility Issue - 3.PNG
ID:	39187   Click image for larger version.
Name:	Visibility Issue - 4.PNG
  8.    #8
    3,188
    04:37 PM
    Did you try making it deeper, far enough that the whole family is within the Primary Range? What category did you assign it to?
  9.    #9
    Member scourdx's Avatar
    July 4, 2013
    58
    04:37 PM
    Check and see if there is filter or object surface pattern turned off. As well if nothing works, try right click and override object by element? Change the surface pattern to glass and then set the transparency to 20%.
  1. Floor Based in-place generic model family won't move in the horizontal direction
    Last Post: September 21st, 2018, 10:32 PM
  2. Editing Generic In Place Model Disappears
    Last Post: July 5th, 2018, 09:05 PM
  3. Model In-Place can join but can't cut Generic Families?
    By billiam in forum Architecture and General Revit Questions
    Last Post: July 4th, 2017, 09:52 AM
  4. any idea on how to rotate Generic model in place from horizontal into vertical?
    Last Post: November 9th, 2011, 02:02 AM
  5. How to place generic model material into reveal?
    Last Post: October 19th, 2011, 10:13 PM
