Thread: Creating a Sheet based parameter that works with client Title Blocks
    August 27, 2019
    Charlotte, NC
    4
    04:33 AM
    I have a need to create some watermarks for my sheet views so that they interact with the title block. The problem is I need this to work without being attached to the title block since we use a different title block for every project. I can easily create a family that gets either loaded into the new title block every time we get one and have that parameter turn on and off, but I'm trying to make this to where our "less than experienced" Revit users can just click on a check box in the sheet view and not have to add it every project.
    Any suggestions?
    Thank you!!
    11,163
    03:33 AM
    If you dont want to do it within your titleblock, i recommend doing it as a second titleblock. Nothing says you cant have two, on the same sheet.
    August 27, 2019
    Charlotte, NC
    4
    04:33 AM
    I didn't even consider that as an option. I appreciate it.
    11,163
    03:33 AM
    Very welcome. Only reason i would like it as a Titleblock instead of simply its own Generic Annotation, is then you can (in any project):
    1. Select a single titleblock thats already on a sheet
    2. Select all instances in entire project (right click)
    3. Copy
    4. Paste Aligned to Same Place
    5. Switch to your watermark type
    I would personally still want something like Dynamo managing it, for when new sheets get added... But its a start.
  1. Conditional Parameter (Title Sheet)
    By BigIdiot in forum Structure - Family Creation
    Last Post: November 7th, 2018, 09:35 PM
  2. Make viewport title multi-line as an instance-based parameter
    Last Post: August 16th, 2018, 08:49 PM
  3. Creating parameter in title block
    By caseym in forum Architecture - Family Creation
    Last Post: April 24th, 2014, 02:57 PM
  4. Sheet Title Blocks, Help Please..
    By denesecouch in forum Architecture and General Revit Questions
    Last Post: March 30th, 2013, 04:03 PM
  5. Shared Parameter and formulas in title blocks
    By Gordon Price in forum Architecture - Family Creation
    Last Post: September 12th, 2011, 05:26 AM
