Thread: How to change a duct shape
    June 11, 2020
    4
    08:23 AM
    How to make a twisted duct
    Good day!
    Is it possible to make this twisted duct in Revit? I am currently working on a condominium project and I need to have this duct shape because we only have a limited space. Thank you for answering!
    September 5, 2019
    20
    04:23 AM
    A reverse transition? I do it with fabrication duct all the time.
    June 11, 2020
    4
    08:23 AM
    Hi! Thanks for answering. Can you explain how are you doing it?
    January 17, 2011
    2,121
    03:23 AM
    If this is a simple reverse transition, then just edit the LxH values on either end of the transition and it'll automatically update. If there is a twist/angle to it, then I wouldn't know how to do it in Revit, but an experienced field guy can.
    -TZ
    June 11, 2020
    4
    08:23 AM
    This is a twist transition. I have already searched a lot but I still got no answer but thanks for responding!
  1. Building Coder: Duct Shape, BipChecker Facelift and @ Fonts
    Last Post: June 22nd, 2020, 07:15 PM
  2. change duct/pipe size
    By philsogood in forum MEP - General
    Last Post: May 2nd, 2017, 11:05 AM
  3. How to change the duct fitting lenth?
    By danezeq in forum MEP - General
    Last Post: July 26th, 2016, 09:09 PM
  4. Changing Pipe/Duct Connection Shape
    By mrgrotey in forum MEP - Family Creation
    Last Post: August 24th, 2015, 03:43 PM
  5. Different Duct Shape/Form
    By bsouzab in forum MEP - General
    Last Post: April 18th, 2012, 02:12 PM
