Thread: Fatal Error
    July 26, 2018
    27
    02:52 PM
    Fatal Error
    Hi! I hope everyone is doing good.
    I have been running into this fatal error problem for sometime now but what I have noticed that it usually happens when I'm starting with flooring and on random nights it'd be trim and extend.
    Can anyone tell me why does this happen? Is anyway to prevent the file from crashing as I'm working on my final year final project.
    Any help would be much appreciated. Thank you!!
    1,674
    11:52 AM
    First thing I would try is open the file with the Audit box selected.
    After that try and clean up your project and remove unneeded stuff.
    Member scourdx's Avatar
    July 4, 2013
    76
    02:52 AM
    Check your errors. I find it less prone to crashing if you keep the errors below 200. Also don't have too many CAD links because any errors in CAD will pass on to Revit.
  1. Revit 2018 Properties Dialogue and Project Browser Frozen after 'fatal error' crash
    By maddyjdelaney in forum Architecture and General Revit Questions
    Last Post: April 16th, 2019, 01:01 PM
  2. Fatal error messages
    By Alex Hockley in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2016, 03:11 PM
  3. Fatal error: Windows has run out of memory
    By barry13 in forum Architecture and General Revit Questions
    Last Post: December 8th, 2015, 05:17 AM
  4. Error fatal editando blends
    By Thasso00 in forum Foro Espaol
    Last Post: March 5th, 2014, 07:02 PM
  5. Exporting DWG and DXF causing fatal error
    By rsloyer in forum Architecture and General Revit Questions
    Last Post: December 14th, 2010, 01:43 PM
