Results 1 to 10 of 17
Thread: Revit Framing
    January 14, 2014
    6
    11:59 AM
    Question Revit Framing
    I've seen in posts (other areas and blogs) that they have the ability to produce the wall & roof framing. How can I do this, is it some other 3rd party software?
    11,252
    01:59 PM
    You can use 3rd party software, or you can use OOTB Structural Columns, Framing Members, and Beam Systems. You can also use a combination.
    January 14, 2014
    6
    11:59 AM
    What is "OOTB"
    11,252
    01:59 PM
    Out Of The Box.
    Studs, Joists, Beams, Headers, Tracks, etc, are all just standard Framing Members that ship with Revit.
    January 14, 2014
    6
    11:59 AM
    Does Revit automatically generate framing, (studs, etc.)? or would be an aftermarket software?
    11,252
    01:59 PM
    In your original post, you didnt use the word Automatically. If you want it done *Automatically,* its 3rd party software or Dynamo, and a LOT of time and effort to set either of them up.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    267
    06:59 PM
    For automatic framing you can look at AGAcad framing
    http://www.aga-cad.com/products/bim-...essional-suite
    If you want to do it by hand, the German OOTB library has some very nice wood framing families.
    Member jsnyder's Avatar
    AUGI Refugee
    357
    11:59 AM
    You could also look at this company (which I have seen at BILT, but never used personally): https://strucsoftsolutions.com/
    May 14, 2019
    12:59 PM
    Quote Originally Posted by jsnyder View Post
    I can share some experience here to this program. I use MWF everyday framing walls and creating shop drawings. It is very helpful but as mentioned previously it takes a lot of up front set up. You need to create all your wall templates and your shop generation templates ideally before you start your framing. However once you do the initial setup in your project and know your workflow it makes wall framing much faster. You still need to do the detail work such as headers and framing for penetrations in the walls but It senses doorways pretty good as long as the template is setup to look and frame for them.
    11,252
    01:59 PM
    Quote Originally Posted by Casual Reviter View Post
    One clarification: it sets up doorways pretty well of you use very simple doors, like OOTB doors. If you leverage Shared Nested frames that punch the openings out of the wall, MWF will completely screw up every single door opening, unless you want to rework all of your shared nested frames to use OOTB parameters for their overall sizing.
    I think it's a great program, but the way it handles division 08 has made me turn a bunch of companies away from using it.
  1. Tagging framing members in Revit via imported TSD
    By Hangman in forum Structure - Interoperability
    Last Post: February 13th, 2018, 05:22 PM
  2. Revit 2017 Framing Extension
    By RussPkr in forum Architecture and General Revit Questions
    Last Post: March 13th, 2017, 11:25 PM
  3. rafter framing in revit wood framing extension
    By Rrbryce in forum Structure - General Questions
    Last Post: October 8th, 2015, 03:59 PM
  4. Revit 2015 framing families
    By Peter1979 in forum Structure - General Questions
    Last Post: August 31st, 2014, 01:42 AM
  5. Replies: 1
    Last Post: May 23rd, 2011, 02:28 PM
