Thread: hiding floor slab in elevation
    February 10, 2018
    10
    09:27 PM
    Question hiding floor slab in elevation
    what is the simple & fastest way to put finish material (plaster/mortar) on the exterior walls?
Name:	Annotation 2020-08-25 121650.png
ID:	39293   Click image for larger version.
Name:	Annotation 2020-08-25 121722.png
ID:	39294   Click image for larger version.
Name:	Annotation 2020-08-25 121735.png
ID:	39295   Click image for larger version.
Name:	Annotation 2020-08-25 121818.png
ID:	39296   Click image for larger version.
Name:	Annotation 2020-08-25 121856.png
Name:	Annotation 2020-08-25 121907.png
ID:	39298   Click image for larger version.
Name:	Annotation 2020-08-25 124015.png
    May 14, 2012
    500
    12:27 PM
    What you're showing is what I'm thinking given the building construction. I'm curious to see if there are other suggestions.
    "OMG I killed Revit"
    dzatto's Avatar
    5,280
    01:27 PM
    That's how I do all of my buildings. One wall for the sheathing and studs, a second wall for the air gap (if there is one) and the finish material. Then join wall so your openings cut both walls. You could create all layers in one wall type (which I did when I first started), but I like the two wall method better. It gives me more control.
    Member scourdx's Avatar
    July 4, 2013
    76
    11:27 AM
    Really depends what phase of the project you are in. Quickest way is use the wall material and paint it to the slab edge. Then join geometry floor slab with the wall. If you want to construct it properly, you can use this base extension which can cover your slab edge. See screenshot below.
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    375
    02:27 PM
    I do multiwall exteriors on all of our buildings as well. It is actually how we have our template set up. In one of my current projects there are actually 3 walls that make up our exterior assembly.
    Wall 1: Gyp, Gyp, Stud (Stops and Starts at top and bottom of the slab)
    Wall 2: Gyp, Gyp Insulation (Passes the Slab)
    Wall 3: Air Space/Brick or Metal Panel (Varies by location)
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    403
    06:27 AM
    You could use a Single Wall, with a Plaster/Concrete/Plaster Materials
    When making the Floor you can then use "Pick Wall" & make it snap to "Core Face" Picking the Concrete portion of the wall
    February 10, 2018
    10
    09:27 PM
    ok so i did what you suggested but it take some time and i need in several cases to edit profile of the finish layer.
    i will try to make the floor slab and the wall with the same material and then join them. it sound good way to model the building.
    Quote Originally Posted by pivoarch View Post
    that sound hard to work like that
    Quote Originally Posted by d.stairmand View Post
    i will try it
Name:	Annotation 2020-08-27 172513.png
ID:	39313   Click image for larger version.
Name:	Annotation 2020-08-27 172532.png
  1. Hiding Floor Plans
    By akaplan in forum Architecture and General Revit Questions
    Last Post: January 28th, 2016, 10:46 PM
  2. Hiding floor 1 when i'm working in floor2
    By ElisaFurla in forum Architecture and General Revit Questions
    Last Post: May 27th, 2015, 01:09 AM
  3. How Can I Hide Slab elevation Lines In Elevation ?
    By YahyaM. in forum Architecture and General Revit Questions
    Last Post: March 19th, 2014, 08:28 AM
  4. hiding elevation tags by type, (in all views)
    By gentlepuppies in forum Architecture and General Revit Questions
    Last Post: April 9th, 2013, 07:12 PM
  5. Hiding geometry in an elevation view
    Last Post: December 4th, 2012, 01:15 AM
