Results 1 to 10 of 10
Thread: Curtain wall border Mullion - Dimension to centerline
    September 21, 2016
    Boston
    309
    06:15 AM
    I am working on a window schedule where we have created various storefront and curtain wall systems with the standard system mullion profiles. The mullions in the middle of the storefront have a center-line that you can snap to when you want to dimension the drawings but the border mullions somehow lose this center snap and I cannot dimension to them, the only option is to snap to the outside end. I want to be able to also dimension to the center-line of the border mullions as well. I tried creating a custom mullion profile using the standard procedure to add a center snap to the profile, but to no avail.
    What are my options? I could use detail lines and snap to them, but I want to avoid detail items at all costs.
    Long Beach, CA
    236
    03:15 AM
    Custom mullions are your solution, but the trick is that you need to introduce a split in the line in your mullion profile. Advantage: you can dimension to the center. Disadvantage: you will see a visible line in your elevations. You can always Linework <Invisible> to hide that line, but it's a 'pick your poison' proposition.
Name:	Mullion Split.jpg
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,579
    03:15 AM
    2 Not allowed! Not allowed!
    Out of curiosity, why do you want to dimension to the center line of a perimeter jamb of a curtain wall system? This dimensional reference is not used by anyone in the glazing industry, be it detailers, fabricators, manufacturers, etc. Module dimensions are always center line of intermediate mullions/horizontals to outside of perimeters (heads, sills, or jambs).
    2,852
    03:15 AM
    Cause Design my friend. Deeesign
    11,259
    05:15 AM
    Have to disagree, there. I work with a TON of Designers. Ive only met a few who didnt understand the basics of how Glazing Systems get dimensioned. The majority of them *get it.*
    But if you must have it: Split the lines on the BACK side of the profile. Place dims in Wireframe mode.
    Long Beach, CA
    236
    03:15 AM
    ....But if you must have it: Split the lines on the BACK side of the profile. Place dims in Wireframe mode.
    Nice! Didn't think of that. But like you, i wouldn't dimension that way either.
    That ^ !
    Dave, i dimension as you explain above, but I understand why designers want to dimension as requested by the OP. As a response to those who want to convey equal size glazing panels, is there a convention that curtain wall/storefront detailers prefer to use? My guess is that it would be the overall dimension, and a nested one from outside of border mullions to CL of intermediates, with a note "EQ. PANELS", or something of the like. I regret that I don't have a set of shops handy to check, nor have looked into that level of minutia as the shops generally met the design intent.
    Jon
    Dave Jones's Avatar
    4,579
    03:15 AM
    Quote Originally Posted by kingjosiah View Post
    Jon
    In my experience generally total modules x width are not equal. Normal is equal modules between grid lines and what is left over on each side. Not an issue to make all equal mods but mullions centered on grid lines makes it easy for all trades to align joints, railing balusters, etc. Example: Edit, not a great example based on my description as obviously for this project the center of modules align with grids. You get the idea though...
Name:	Curtain Wall Dims.jpg
  8.    #8
    2,852
    03:15 AM
    What does the MD mean on that dimension string?
  9.    #9
    Dave Jones's Avatar
    4,579
    03:15 AM
    MD = Module Dimension = center line to center line of intermediate members or center line of intermediate member to outside edge of perimeter members
  10.    #10
    Long Beach, CA
    236
    03:15 AM
    DLO. Daylight Opening! That was the term i was trying to remember. So it sounds like a consistent panel size for all panels, including the ends is not that critical from an economy standpoint? Guess that makes sense since the glazier is cutting all sheets to size per project.
    Anyway, thanks for the example above, Dave.
  1. Custom Curtain Wall Border Mullions Not Joining
    By Kawlos in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2017, 04:36 PM
  2. Dimension to linked file wall core centerline???
    By kwandrew2 in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2017, 10:56 PM
  3. Curtain wall border Mullion - Profile to align at the centerline
    By kubbah in forum Architecture - Family Creation
    Last Post: December 5th, 2014, 11:28 PM
  4. Curtain Wall Border Mullions
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: April 18th, 2013, 04:34 PM
  5. Curtain Wall / Sloped Glazing Border Mullion
    Last Post: April 11th, 2012, 09:33 PM
