Results 1 to 10 of 12
Thread: Areas
    March 4, 2012
    15
    11:12 AM
    Areas
    Copy/Paste areas from one level to another losing actual areas, anyone else experienced the same ?
    Thanks
    3,382
    06:12 AM
    Areas are defined by their Boundaries.
    If you're not also copying the Boundary Lines, yes, they will lose the area.
    March 4, 2012
    15
    11:12 AM
    yep, boundaries are copied as well, it seems that areas are level specific and cannot be changed from level to level.
    2,822
    09:12 PM
    You can't just select an area and change it's level but you sure can be copy paste between levels. Paste aligned current view / selected level should do it. You can even put them in groups if you're a nihilist
    After pasting make sure the reference level is correct.
    March 4, 2012
    15
    11:12 AM
    yep, tried all of the above, paste in place, group, paste in place, just warns me about duplicates, so no joy of changing the referencing level
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    375
    07:12 AM
    It definitely is possible. We do it all the time in towers to copy areas from one level to the 20 identical levels. I'm not sure why it isn't working for you but it works.
    3,382
    06:12 AM
    Quote Originally Posted by xeex View Post
    Wait, "paste in place"?
    That means paste it in the exact same place you copied it from.
    As Elton said, Paste to Selected Level or Paste to Current View (after changing to a View on the target Level)
  8.    #8
    March 4, 2012
    15
    11:12 AM
    I know that it can be copied to different levels, i do the same, especially when grouping them, but in my case I guess i should have been more specific, it does not work if the level created is at the same elevation: this was mentioned a while ago https://revitclinic.typepad.com/my_w...on-levels.html
    the areas and the area schemes are not copied (area boundaries are already there)
  9.    #9
    March 16, 2011
    Princeton, NJ
    375
    07:12 AM
    Now I'm curious. What would be the need to have two levels at the same elevation?
  10.    #10
    March 4, 2012
    15
    11:12 AM
    bad modeling practice, creating a common level and creating geometry for multiple buildings, rather than having individual level for each building
  1. Custom Areas added to Room Areas
    By Munkholm in forum Dynamo BIM
    Last Post: February 18th, 2016, 01:13 PM
  2. Areas 'Not Placed' in schedule...
    By Beno in forum Architecture and General Revit Questions
    Last Post: January 14th, 2016, 06:57 AM
  3. Areas
    By madsagger in forum Architecture and General Revit Questions
    Last Post: November 21st, 2014, 06:02 AM
  4. Scheduling Areas from multiple files. Can blank rows be added for missing areas?
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2014, 12:10 AM
  5. Areas
    By assem in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 12th, 2011, 07:40 PM
