Thread: Roof slope
    May 31, 2018
    Quebec, Canada
    153
    09:02 PM
    Roof slope
    Hi everyone,
    I am trying to do this roof slope ( in front)
    But my corner is weird as hell..
    even if I change my slope, it doesnt look clean.
ID:	39351Click image for larger version.
    I would like the slope to reach this corner is there a easy way to do it?
    thanks
    I had to do it in 2 roofs or it was weird somewhere else
    December 20, 2010
    1,148
    05:02 PM
    If the eave heights are all the same it should be possible in one roof, its not totally clear to me what you are trying to do. But if you want the highlighted blue roof to continue to the face of the second roof, edit its sketch to do so but Don't make it slope defining. Leave only the main roof sketch line slope defining and it will continue to slope down to the next sketch line. So basically , edit sketch of the highlighted roof and trace the edge of the front roof, then make sure none of the new lines are slope defining. then use join geometry to clean it up.
    May 31, 2018
    Quebec, Canada
    153
    09:02 PM
    hey Sir,
    Thanks for your reply, sorry I was super busy!
    Here is my problem, see the ketch on the left? it doesnt suit well at all
ID:	39393Click image for larger version.
    May 31, 2018
    Quebec, Canada
    153
    09:02 PM
    bump
    Long Beach, CA
    236
    02:02 PM
    Hi Midaz,
    It is still very unclear what you want the finished product to look like. The "street view" photo is at the wrong angle and does not show the desired condition in a manner that can be understood. That said, with little idea with how this condition should be modeled, you can try this as shown in the image attached below. Again, it's a total shot in the dark since i can't determine what you want.
    Let the roof boundary continue out to where the red dashed lines are, then use a vertical opening (orange) to cut the roof back to the finished location. It will eliminate unwanted valleys and ridges.
    If that doesn't help, pls send another precedent photo that better explains the condition.
    Jon
    May 31, 2018
    Quebec, Canada
    153
    09:02 PM
    So part 1 I want the garage roof to have a 20" offset , to have a little slope in front.
    Like this picture, the roof in front doesnt finish traight, there is a slope on the left of the garage roof.
    Part 2: how do I level jsut the back part of the roof, to make the water leave by the rear, I can't have a slope that is is going down to the facade
    Is it more clear? ahah
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    406
    10:02 AM
    Yep that can be all done
    see the attached file
    Its made from a 3 Roof's & shouldn't be too hard for you to replicate
    Sometimes trying to use a Single roof can be a bit troublesome
    Edit each of the Roof's to see how i have done it & note where the Slopes have been defined from
  8.    #8
    May 31, 2018
    Quebec, Canada
    153
    09:02 PM
    Awesome thanks my friend, you are awesome!
    it is funny because I worked my a.. to make it work and it is not what he wanted finally.. ahah
    learning experience!
  1. Slope a roof with circular end
    By New2Revit in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2018, 07:23 PM
  2. Slope Roof
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: October 5th, 2016, 03:22 AM
  3. Roof slope!
    By Jamma79 in forum Architecture and General Revit Questions
    Last Post: July 16th, 2015, 10:39 PM
  4. Roof Slope assymetric
    By Damo in forum Architecture and General Revit Questions
    Last Post: February 19th, 2015, 05:46 PM
  5. Calculate Roof Area for Slope Glazing roof
    Last Post: October 31st, 2011, 06:54 PM
