Results 1 to 2 of 2
Thread: Help for a noob
    December 16, 2010
    941
    10:51 AM
    Help for a noob
    Hi Dynamo users.
    I am a total debutant and noob with Dynamo.
    I am pretty sure it will be the solution for a problem that I have, but I am not really sure where to get started. I heard that there are often pre-made packages that are part of modules but I don't even know where to start. Maybe someone could point me in the right direction?
    I am looking for a script (or whatever they are called) that will let me do the following:
    Find the point along a model line and extract the coordinates (x,y,z)
    Take those coordinates and place a family with adaptive point at those coordinates.
    Seems simple, I am guessing it should be, but when I started with dynamo I couldnt figure much out.
    I also would like a phase 2 to that script where if there are modifications it could move the object from place 1 on an old model line, to place 2 on the new line.
    Any help is appreciated.
    November 4, 2012
    Budapest, Hungary
    152
    02:51 AM
    Start here: https://primer.dynamobim.org/
    If you've read through the primer, you should be able to extract the points from the model line. You can place an adaptive family with the OOTB AdaptiveComponent.ByPoints node.
    If you need someone to develop this for you, you can post a request in the dynamo forums jobs section: https://forum.dynamobim.com/c/jobs/14
  1. Revit Server Noob
    By antman in forum Worksharing and Cloud Coordination
    Last Post: February 21st, 2014, 08:44 PM
  2. A little help for a noob...
    By kahanamoku in forum Architecture and General Revit Questions
    Last Post: January 28th, 2013, 01:44 PM
  3. NOOB question: what did I dimension to?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: August 4th, 2012, 04:00 PM
  4. NOOB roof questions
    Last Post: December 23rd, 2011, 05:29 PM
  5. Beam system:noob question
    By jbenoit44 in forum Structure - General Questions
    Last Post: March 27th, 2011, 11:37 PM
