Thread: AutoCAD background file scale seems off
    September 11, 2020
    07:58 PM
    I am teaching a Commercial Revit course where I am having the students create a 12 story building. I had them first create their base site plan in AutoCAD and import it in. I took this class myself several years ago so I brought up my previous project to see if I could build it again (it's been a while!).
    The first problem I noticed is that when I bring in my site plan and start building on top of it, an 8" thick wall seems huge! The scale is way off, even though it matches my previous project at 1"=20'. When I measure my project, one wall is 151'. That same wall that I added in into the new project I started is only 14'. What am I missing here?
    Floor 1 is set to 1/8"=1'.
    I appreciate any help as I am obviously a little Revit rusty!
    Member scourdx's Avatar
    July 4, 2013
    76
    05:58 PM
    Before you link in Revit, did you check what unit that drawing is drawn at? Usually if you use auto-detect, it will mess up with the scale especially if your AutoCAD is set to unitless. Check AutoCAD Units and see what insertion unit it is using. Then when you link the CAD into Revit, it will set to correct scale.
    2,825
    10:58 AM
    As above check the scale first.
    Also, always link into an active view, not a sheet, not an active view on a sheet.
    September 11, 2020
    07:58 PM
    Thumbs up
    Perfect! That was the issue!
  1. Importing AutoCAD file for Topo Surface
    By Rwright in forum Architecture and General Revit Questions
    Last Post: November 1st, 2016, 07:03 PM
  2. 3D AutoCAD Dwg File Imported Into Family
    By koolair in forum MEP - General
    Last Post: July 7th, 2015, 08:30 PM
  3. Link a Autocad file
    By landskab123 in forum Worksharing and Cloud Coordination
    Last Post: February 19th, 2014, 07:47 AM
  4. Topography from an AutoCAD file with points
    By fubar_69 in forum Architecture and General Revit Questions
    Last Post: October 17th, 2013, 05:57 PM
