Thread: Can't find and delete Revit Levels
    December 19, 2018
    6
    01:26 PM
    I'm having a problem with the levels in my project. I created 4 of my own levels, and the project had 4 generic levels already in it when I created it.
    The problem I'm running into is that I can't see the levels that were already in the project (Foundation level, 0'-0" Level, Finish Slab, and LOWER FOUNDATION) in any view. If I create a section or elevation all I see are the levels I created. Even if I select everything in the view and look at filter, it only has 4 levels selected. Does anyone know what is happening here? I'd really like to clean up my project manager.
    11,255
    01:26 PM
    2 Not allowed! Not allowed!
    They are probably out in space (their 3D extents are not maximized).
    Grab a level you created, right click, Select All Instances in entire Project, right click, Maximize 3d extents.
    December 19, 2018
    6
    01:26 PM
    That did the trick! Thank you!
    Member Exar Kun's Avatar
    August 2, 2011
    225
    04:26 AM
    If you are just looking to delete levels in your project that you can't find you can also create a level schedule, sort & group by name then delete rows from it.
    Member duende123's Avatar
    November 20, 2015
    222
    02:26 PM
    be careful
    when a level is deleted all the objects related to it are deleted
    it is dangerous
    2,820
    04:26 AM
    Quote Originally Posted by duende123 View Post
    be careful
    it is dangerous
    Agreed it is dangerous as you won't even get warnings. Use dynamo to find all elements hosted to the level first.
  1. How to delete/find hidden revclouds?
    By Chiater in forum Architecture and General Revit Questions
    Last Post: May 30th, 2016, 10:19 PM
  2. Delete Hard to Find Levels
    By nod684 in forum Architecture and General Revit Questions
    Last Post: March 15th, 2016, 10:28 AM
  3. How do I 'delete' LEVELS AND GRIDS from a RVT Link?
    By allan120791 in forum Worksharing and Cloud Coordination
    Last Post: December 7th, 2013, 05:39 PM
  4. title block parameters - can't find to delete?
    By CBukowski in forum Architecture and General Revit Questions
    Last Post: November 27th, 2012, 02:43 PM
  5. Deleting Levels will delete other views
    Last Post: January 12th, 2012, 12:42 AM
