Thread: Revit gable roof problems
    Lurker
    September 10, 2020
    11:06 PM
    Where am I going wrong with the below gable roof? I am trying to extend the wall up to the roof but am being left with this gap.
ID:	39398Click image for larger version.
    1,688
    12:06 AM
    difficult to say, but you see a smal vertical line on the side of the roof at the same location as where the wall is, makes me think something is going on there.
    But I would start to make the roofs as they are going to be, I see pieces of roof tile that are not going to be there once build (where your arrow is for example) This might solve some of the issue as well.
    3,202
    03:06 PM
    If you're attaching the wall to both roofs only one can "rule"... The gap is there because the "other" roof has pulled the wall "down" to it instead of the other higher roof. To get the wall to attach to both roofs you'll need to split the wall where the roofs overlap or create wall under one roof and another wall under the other roof alone.
  1. Roof - Dutch Gable
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: March 25th, 2020, 07:56 PM
  2. Attaching gable walls to roof
    By Ecotech Kid in forum Architecture and General Revit Questions
    Last Post: May 1st, 2017, 05:11 PM
  3. Gable Roof Terminology
    By radiotronique in forum Architecture and General Revit Questions
    Last Post: August 15th, 2016, 02:13 PM
  4. Sloped gable roof from storefront
    Last Post: July 5th, 2012, 03:01 PM
  5. fascia join - gable roof
    By mleverant in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2012, 07:21 PM
