Thread: Roof Edges are see-through through walls
    September 14, 2020
    4
    05:44 PM
    Hi all,
    The roofing is made of plywood sheathing sloped at an angle of 1/4" per 12" downwards (not sure if this affects the visibility). I have been messing around with it for 2 hours but have not resolved how to hide certain roof lines in the model, and am unsure how to add them in the places that I want. Below are 2 areas where I want them to not be see-through and 1 area which I do want the edges to be seen.
ID:	39412Click image for larger version.
ID:	39413Click image for larger version.
    September 14, 2020
    4
    05:44 PM
    bump
    Long Beach, CA
    236
    05:44 PM
    A few things for you to check
    1. Is your view set to wireframe? This does not appear to your problem
    2. Are the walls set to be transparent in this view?
    3. Do you have any .dwg links appearing in this view? I have seen cad files cause elements to render as transparent even though they are not. If there are links, unload them or suppress all imports, and see if that resolves your problem.
    Jon
  1. Recessed Roof Extending Into Walls
    By Andycmac in forum Architecture and General Revit Questions
    Last Post: June 17th, 2017, 11:42 AM
  2. Curved walls + roof by footprint
    By HSG11 in forum Architecture and General Revit Questions
    Last Post: May 4th, 2017, 01:31 PM
  3. outline of walls below roof showing
    By philliano in forum Architecture and General Revit Questions
    Last Post: February 21st, 2015, 10:02 AM
  4. Strategy; roof or 2nd story walls first?
    By Arniedraws in forum Architecture and General Revit Questions
    Last Post: January 2nd, 2015, 02:12 PM
  5. Can't select walls attached to roof.
    By JDS3 in forum Architecture and General Revit Questions
    Last Post: July 19th, 2014, 12:33 PM
