Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Linked Model - Mark Parameter
  1.    #11
    4,466
    07:40 PM
    Unless I've misread, you've only said schedule so far (not tag) so confused how this doesn't suffice:
  2.    #12
    3,202
    11:40 AM
    How likely are the foundation elements for each location to actually be identical to other locations? Soil conditions often vary over a large site no?
  3.    #13
    Member MartinGT's Avatar
    August 17, 2011
    UK
    286
    07:40 PM
    Totally forgot one of the first rule of Revit - KISS (Keep it Simple Silly) Over the weekend I had a small Eureka moment.
    Instead of creating a model with several families inserted into it, then putting that into a site model I have found a solution that works.
    I created the foundations as a family. Then I have placed that into the model and now I have no problems tagging / changing marks / scheduling at all.
    As the foundations are just ground beams with piles, it's just like having a pilecap family. Simple.
  4.    #14
    4,466
    07:40 PM
    Glad to hear you found a solution - but just for those (me) who can't picture it... what do you mean? how were the foundations not a family before? Do you mean you were using a the system family variety prior? Either way, how have you got past the linked-instance issue - or have you resorted to the one-model-for-foundations route?
  5.    #15
    August 17, 2011
    UK
    286
    07:40 PM
    I've attached a sample project, that should explain it a bit better than I can in words.
    Let me know if you can't open it.
  1. Linked model share parameter value in the Schedule.
    By swapr78 in forum Architecture and General Revit Questions
    Last Post: August 7th, 2020, 03:27 PM
  2. No Centerline Mark if Dim'ing a linked model?
    By David Thigpen in forum Architecture and General Revit Questions
    Last Post: June 30th, 2020, 01:19 PM
  3. Type Mark (and Material Mark) linked to Sheet Number or Name
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: September 11th, 2017, 04:20 PM
  4. Associate 3D Model Text parameter with the Mark Parameter in a project?
    By tzframpton in forum Architecture - Family Creation
    Last Post: July 11th, 2016, 10:04 AM
  5. Mark parameter variance by linked file instance
    Last Post: July 9th, 2014, 02:31 PM
