Thread: Crop Region Issue
    May 14, 2020
    13
    12:46 AM
    Crop Region Issue
    Hi All,
    I'm having an issue with a cropped view in Revit. I have an irregular shaped crop region. The linked model get cropped to that shape but there are parts that aren't cropped: the light room tags and also my fixture tags are visible. Annotation crop is selected so I was confused on why this is happening.
    Also I cannot use a masked/filled region for this view to hide that area since this view is duplicate as dependent. I'm trying to avoid having to create a separate view for this to use masked/filled region because I'd have to do it for all drawings for each trade. Is there another reason why these tags are visible after cropping?
    Thank you
Name:	crop region.PNG
ID:	39419   Click image for larger version.
Name:	cropped issue.PNG
    Member scourdx's Avatar
    July 4, 2013
    76
    05:46 PM
    The cropped view and annotation crop are totally different. If you create custom cropped view, the annotation will not follow the custom cropped view. It will still have the big crop box. Your option now is to hide it using hide by element or by filter.
    May 14, 2020
    13
    12:46 AM
    Thank you for the response. Hiding by element would be tedious since there are multiple trades. I was thinking of creating a fill region and applying that to multiple views. But the issue I'm having is that the fixture and room tags are still visible. Is there a way to have the fill region cover the tags as well?
    July 4, 2013
    76
    05:46 PM
    You can use the UBER Masking. It will hide your annotation and grids
    May 14, 2020
    13
    12:46 AM
    Thank you, much appreciated!
  1. Edited Crop Region Does Not Crop Filled Region When Printed to PDF
    By KEastman in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2020, 10:18 PM
  2. 3D Perspective Crop Region visibility issue
    Last Post: December 27th, 2019, 01:41 PM
  3. section mark still show up way beyond crop region and annotation crop
    Last Post: November 5th, 2017, 05:42 PM
  4. links outside the crop region
    Last Post: May 18th, 2016, 03:33 AM
  5. 2014: Is the new Crop Region really just a Masking Region?
    Last Post: July 31st, 2013, 10:26 PM
