Thread: Revit window family
    Lurker
    September 16, 2020
    12:02 PM
    Revit window family
    Hello, and thank you for accepting me!
    I'm a somewhat new Revit user (around a year) and I need to model a window family that has the following parameters:
    - variable number of divisions;
    - the divisions should be possible to have variable dimensions.
    I have modeled in the past windows that had a variable number of divisions using Array, but that means all divisions will be equal. I can easily model a family with a fixed amount of divisions and variable lengths - but I do not know if there is a way to do both.
    1,685
    11:02 AM
    Sure can be done, but that will get complicated.
    If I would have to come up with a way from the top of my head, it would not be an array, because of what you mention, but probably have the max number of divisions in them and then use the Visibility parameter to hide the elements you don't need with some formula to control that. So if you need a division of 2 (1 mullion) all the other mullions will be invisible.
    I have gone the route of making different windows for different amount of divisions and then you can add dimensions to each division, like Cell_1_Width, Cell_2_Width, etc.
    4,466
    10:02 AM
    Quote Originally Posted by Oana Rusu View Post
    Welcome to the forum!
    ...Curtain Wall.
    1,685
    11:02 AM
    Curtain Wall.
    or there is that
  1. Quirky Revit 2017 Window Family Model Line Behavior
    By Barth in forum Architecture and General Revit Questions
    Last Post: June 7th, 2016, 03:23 AM
  2. Revit Kid: Revit Tip - Nested Window Family Issue
    By The Revit Kid in forum Blog Feeds
    Last Post: April 13th, 2015, 12:15 PM
  3. Convert window family into curtain wall panel family
    By amolese in forum Architecture - Family Creation
    Last Post: January 27th, 2015, 02:20 PM
  4. Window Family
    By GStas in forum Architecture - Family Creation
    Last Post: April 21st, 2014, 05:01 PM
  5. Window famility to host a window family
    By JasonWallis in forum Structure - Family Creation
    Last Post: January 30th, 2013, 11:27 PM
